    May 2010
    Canada
    Windows 7 (x64)
    using: ffmpeg-20151205-git-a16243a-win64-static
    http://ffmpeg.zeranoe.com/builds/
    I tried to convert a DCP/4K video of the open-source project "Tears of Steel" (because I didn't want to download all the lossless pictures).
    https://mango.blender.org/download/
    https://mango.blender.org/production/watch-the-film-in-4k/
    https://media.xiph.org/tearsofsteel/
    They don't really say how big the 4K TIF archive is, but I imagine much more than 16GB for the DCP.
    But using this (which worked before):
    ffmpeg -i "G:\Import\Video_OpenSource\Tears of Steel\Tears of Steel [4K] [DCP]\tos_picture.mxf" -vcodec ffvhuff  -pix_fmt yuv444p16le "tos_picture.avi"
    gives me this in the window:
    [mxf @ 02008740] "OPAtom" with 2 ECs - assuming OP1a
    Input #0, mxf, from 'G:\Import\Video_OpenSource\Tears of Steel\Tears of Steel [4K] [DCP]\tos_picture.mxf':
    Metadata:
    timecode : 00:00:00:00
    Duration: 00:12:14.00, start: 0.000000, bitrate: 146830 kb/s
    Stream #0:0: Video: jpeg2000, rgb48le (12 bpc), 4096x1714, 24 tbr, 24 tbn, 24 tbc
    Incompatible pixel format 'yuv444p16le' for codec 'ffvhuff', auto-selecting format 'yuv420p'
    Output #0, avi, to 'tos_picture.avi':
    Metadata:
    ISMP : 00:00:00:00
    ISFT : Lavf55.0.100
    Stream #0:0: Video: ffvhuff (FFVH / 0x48564646), yuv420p, 4096x1714, q=2-31, 200 kb/s, 24 tbn, 24 tbc
    Stream mapping:
    Stream #0:0 -> #0:0 (libopenjpeg -> ffvhuff)
    Press [q] to stop, [?] for help
    frame= 1 fps=0.1 q=0.0 Lsize= 4023kB time=00:00:00.04 bitrate=790931.9kbits/s
    video:4017kB audio:0kB subtitle:0 global headers:0kB muxing overhead 0.139192%
    I was going to use ffmpeg to convert from 12bit/XYZ /444 to 16bit/YUV/444 and use Dither_tools in avisynth to resize to 1080p over their internal 1080p encode.
    I was also going to play with it in SVP (Smooth Video Project)/InterFrame (svpflow libraries).
    This used to work before, but in recent editions, I'm not sure where, something changed so it's not letting me convert to anything but yuv420p.
    I tried ffmpeg's git repository, mailing list, bug tracker, source code, and Zeranoe's forums.
    But I just see the same thing everywhere.
    This thread lists pix_fmt for ffvhuff:
    https://forum.videohelp.com/threads/375561-Info-Pixel-Formats-per-Video-Encoder-%28FFMpeg%29
    yuv444p16le is listed there.
    Using specialized help function to limit help for ffvhuff I see:
    ffmpeg -h encoder=ffvhuff
    ffmpeg -h encoder=ffvhuff >>Encoder_ffvhuff.txt
    Encoder ffvhuff [Huffyuv FFmpeg variant]:
    Threading capabilities: no
    Supported pixel formats: yuv420p yuv422p rgb24 bgra
    The supported pixel formats dropped drastically recently.
    Yet none of the code or logs show anything about the pix_fmt change, related to ffvhuff. Most of it is related to other codecs.
    https://github.com/FFmpeg/FFmpeg/blob/b9cd3e1add3a3db86aaeba8680ad5a4ee57d519b/libavco...c/huffyuvenc.c
    http://git.videolan.org/?p=ffmpeg.git&a=search&h=HEAD&st=commit&s=pixel+format
    I could break it down to TIF images and then use imagemagick to batch everything.
    also, I don't think it's converting from XYZ (internally updated to rgb48le for more precision) to anything you tell it to anymore.
    I read somewhere that ffmpeg now reads it as rgb48le to allow more precision for decoding.
    FFMPEG says it's straight up rgb48le.
    [mxf @ 021f8620] "OPAtom" with 2 ECs - assuming OP1a
    Metadata:
    At least one output file must be specified
    ffprobe say it's xyz12le.
    [mxf @ 0000000000346280] "OPAtom" with 2 ECs - assuming OP1a
    Metadata:
    uid : e2c6f645-b8c7-4f79-a45f-ba34e9959592
    generation_uid : bcd54e36-5843-486c-b973-d9a1a78e839a
    company_name : OpenDCP
    product_name : OpenDCP
    product_version : 0.27.1
    product_uid : 43059a1d-0432-4101-b83f-736815acf31d
    modification_date: 2013-05-14 11:49:51
    application_platform: unix
    material_package_umid: 0x060A2B340101010501010F20130000006B90EF244C8A439D 938F7808426E5520
    material_package_name: AS-DCP Material Package
    Stream #0:0: Video: jpeg2000 (JPEG 2000 digital cinema 4K), xyz12le, 4096x1714, SAR 1:1 DAR 2048:857, 24 tbr, 24 tbn, 24 tbc
    Metadata:
    file_package_umid: 0x060A2B340101010501010F201300000064FE189527CA44F3 A3FF2288AA2D0A08
    file_package_name: File Package: SMPTE 429-4 frame wrapping of JPEG 2000 codestreams
    But MediaInfo ( v0.7.80 ) says it's:
    General
    Complete name : G:\Import\Video_OpenSource\Tears of Steel\Tears of Steel [4K] [DCP]\tos_picture.mxf
    Format : MXF
    Format version : 1.2
    Format profile : OP-Atom
    Format settings : Closed / Complete
    File size : 12.5 GiB
    Duration : 12mn 14s
    Overall bit rate : 147 Mbps
    Package name : AS-DCP Material Package / File Package: SMPTE 429-4 frame wrapping of JPEG 2000 codestreams
    Encoded date : 2013-05-14 11:49:51.000
    Writing application : OpenDCP OpenDCP 0.27.1
    Writing library : unix 1.8.44.27240.1
    Video
    Format : JPEG 2000
    Format profile : D-Cinema 4k
    Format settings, wrapping m : Frame
    Codec ID : 0D010301020C0100-0401020203010104
    Duration : 12mn 14s
    Bit rate : 147 Mbps
    Width : 4 096 pixels
    Height : 1 714 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 24.000 fps
    Color space : XYZ
    Chroma subsampling : 4:4:4
    Bit depth : 12 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.871
    Stream size : 12.5 GiB (100%)
    Title : Picture Track
    Converting from MXF/XYZ to ffvhuff or even with ffv1 in any colorspace (yv12, yuy2/yv16, rgb), it comes out green.
    I searched about the 5 sites using different keywords to see any changes made and what I should do now with new changes.
    It seems docs are all outdated?
    I don't think anyone uses ffvhuff much to merit immediate notice.
    Any insight on what's going on and what I should change would be great.
    I'm going to be back tracking to previous versions where this wasn't an issue for an idea when things changed.
    May 2010
    Canada
    Update:
    ffmpeg-20151101-git-dee7440-win64-static
    works like good ol' times. Even xyz2rgb conversion.
    Did a 2 second conversion on Tears of Steel and it wasn't Matrix-green.
    So, I don't have to back track too far to see what changed.
    E:\Temp\tos>"E:\Downloads\Compressed\ffmpeg-20151101-git-dee7440-win64-static\bin\ffmpeg.exe" -ss 00:00:20.000 -i "G:\Import\Video_OpenSource\Tears of Stee
    l\Tears of Steel [4K] [DCP]\tos_picture.mxf" -y -t 00:00:02.000 -vcodec ffvhuff -pix_fmt yuv444p16le -pred plane "tos_picture.avi"
    ffmpeg version N-76419-gdee7440 Copyright (c) 2000-2015 the FFmpeg developers
    built with gcc 5.2.0 (GCC)
    configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls -
    -enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm
    --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enab
    le-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --e
    nable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-li
    bxvid --enable-lzma --enable-decklink --enable-zlib
    libavutil 55. 5.100 / 55. 5.100
    libavcodec 57. 13.102 / 57. 13.102
    libavformat 57. 13.100 / 57. 13.100
    libavdevice 57. 0.100 / 57. 0.100
    libavfilter 6. 14.101 / 6. 14.101
    libswscale 4. 0.100 / 4. 0.100
    libswresample 2. 0.100 / 2. 0.100
    libpostproc 54. 0.100 / 54. 0.100
    [mxf @ 00000000003e4580] "OPAtom" with 2 ECs - assuming OP1a
    Metadata:
    Metadata:
    Metadata:
    ISMP : 00:00:00:00
    ISFT : Lavf57.13.100
    Stream #0:0: Video: ffvhuff (FFVH / 0x48564646), yuv444p16le, 4096x1714 [SAR 1:1 DAR 2048:857], q=2-31, 200 kb/s, 24 fps, 24 tbn, 24 tbc
    Metadata:
    encoder : Lavc57.13.102 ffvhuff
    Stream mapping:
    Stream #0:0 -> #0:0 (jpeg2000 (native) -> ffvhuff (native))
    frame= 48 fps=1.7 q=-0.0 Lsize= 1241555kB time=00:00:02.00 bitrate=5085409.6kbits/s
    video:1241547kB audio:0kB subtitle:0kB other streams:0kB global headers:1kB muxing overhead: 0.000621%
  3. Seem that something must be wrong:
    Looks like lot of format supported - i would advise to contact directly with Michael Niedermayer.
    Last commit was done on 21 October.
    May 2010
    Canada
    I did tests with all versions and they all worked out.
    I only did a tiniest sample ever to see how it starts operations.
    I didn't even read the full read out for the console window.
    But, apparently, it's using FFMPEG from somewhere else in one of the PATHs.
    version: N-76419-gdee7440 from 2013.
    I thought I checked all the user/system paths.
    But doing a check on ffmpeg.exe, I see a lot of installed versions from somewheres.
    I started using a direct call to ffmpeg with quotations.
    I used to have a solid folder just for updated nightlies of ffmpeg in the system path.
    But, I guess something I installed recently added a new ffmpeg with a new path.
    Looks like it might not be a real issue.
    With latest "20151205-git-a16243a" instead of "N-76419-gdee7440" and no loss of yuv444p16le.
    Checking through ProcessLasso log, it came from ImageMagick.
    I only installed because I was too lazy to keep updating the portable folder for that, too. I use it less than ffmpeg. lol
    Sorry for false alarm, everyone.
    Lesson learned? Never install everything under the sun.
