Anyone ever converted a video stream that has some interlaced components in it with BDRebuilder??
I am attaching the media information...not sure if there are any hidden settings that should be used. I've only used progressive before.
Cheers
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
By default, BD Rebuilder keeps progressive video as progressive and interlaced video as interlaced. As long as you don't change any default settings, the encoded video will be the same as source video type even if it's a mixed disc.
However, there are hidden settings to deinterlace interlaced video and IVTC film content. The video will then be encoded as progressive. -
oh...ok...great!! thanks for the info!
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Never used BDRebuilder; just a few theoretical remarks:
If you have a video source with "hybrid content" (some progressive scenes, some interlaced scenes), you would best encode the whole video as interlaced and trust in MBAFF making the right choice per scene and slice.
If you have FullHD resolution (1080 lines), Blu-ray compatibility would require interlaced encoding regardless of the content. If you are sure that the content is in fact progressive, x264 offers "fake interlacing" (the video stream will be flagged as "interlaced - MBAFF" to satisfy the Blu-ray specs, but the MBAFF choice will certainly prefer progressive slices).
Help me with this 1080i MBAFF 29.970 fps file.
By protoX in forum EditingReplies: 2Last Post: 25th Nov 2014, 04:46 -
Jitter in encoded SD MPEG-2 from MBAFF H.264 1080i file - why?
By Killer3737 in forum Video ConversionReplies: 21Last Post: 4th Nov 2014, 12:25 -
Problems encoding MBAFF H.264 stream
By Killer3737 in forum Video ConversionReplies: 22Last Post: 24th Aug 2011, 19:38 -
25fps BD with MBAFF to 23.976
By Anonymous344 in forum Video ConversionReplies: 11Last Post: 5th Jun 2011, 19:21 -
is it possible to de-interlace MBAFF video?
By deadrats in forum Video ConversionReplies: 4Last Post: 17th Feb 2011, 22:08
