I have been trying to digitize old video 8 tapes so I borrowed a Sony CCD-Tr400 camcorder to play the tapes. Many of the tapes are being split when rewinding or getting crunched up. Is this a problem with the camcorder or the age of the tapes (30+ years old)? Would a standalone 8mm tape player be more gentle on the tapes? I really don't want to spend too much for a standalone as I just need to output from s-video/composite to the computer for digitizing.
It's probably the camcorder, though poorly stored tapes can cause problems too.
At the risk of courting controversy, I would recommend you consider a Digital 8 deck or camera for digitizing to the computer.
S-Video under ideal circumstances (well conditioned deck + TBC + top notch capture card + lossless codec + avisynth post-processing) is certainly best, but using a D8 deck will get you 95%+ of the way there with a lot less hassle. -
Thanks for your advice. I would love to get a deck like the GV-D200 but they are a little pricey. Looking at the DCR-TRV340 or TRV740 camcorder instead and hoping they do as good a job.
A word of warning on the Digital8 cams: I have a Sony that does the A/D conversion and provides a DV stream over IEEE1394, which is very convenient. But it seems to add setup (7.5 IRE) so the black level is too high. The bug is circumvented by using analog output and an external converter.
Capturing Video8/Hi8
By pvrbulls in forum Capturing and VCRReplies: 13Last Post: 12th Feb 2017, 09:31 -
Can Hi8 distorted tapes recorded on 8mm camcorder, play on Hi8 camcorder?
By RebeccaJB in forum Newbie / General discussionsReplies: 7Last Post: 27th Jul 2014, 18:39 -
Video8 camcorder - can it use Digital8 tapes?
By slow in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 22nd Feb 2014, 04:51 -
Hi8 Camcorder not detecting tapes?
By euon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Jan 2014, 00:40 -
Video8 and Hi8 and Camcorders
By Sartorius48 in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2013, 19:40
