Hi,
can you recommend me a video player for my new Android Smart TV Philips?
I don't like the player of the TV because it does not support external subtitles over DLNA.
I nee player with good subtitle support and options (size and position).
Any help will be much appreciated. Thanks in advance.
There is still the problem of installing the player on the OP's Philips smart TV. The question is will the OP's Philips smart TV allow him to install an app not obtained via the TV's official apps list? If not then he'd have to try to root/jailbreak the TV.
[Edit]I guess there is a way to install foreign apps for at least some Philips Smart TVs, but someone would use it at their own risk: http://blog.ostebaronen.dk/2015/06/enabling-unknown-sources-on-phillips.htmlLast edited by usually_quiet; 7th Dec 2015 at 12:03.
If you have no access to google play can you try install from android apks, http://get.videolan.org/vlc-android/1.7.0/ . If you now can download and run apks on the tv android version...
Is it possible to transfer files from cheap Android phone to mp3 player
By jimdagys in forum ComputerReplies: 10Last Post: 21st Nov 2015, 11:31 -
Android - How do I play back files from a NAS on an Android phone/Tablet?
By Goodgrief in forum Software PlayingReplies: 3Last Post: 8th May 2015, 13:04 -
Which is the best Android and IOS Smart phone video capture application?
By Stears555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 18th Jan 2015, 17:50 -
Roku vs Android based (streaming) media player
By indijay in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2012, 06:54 -
Samsung Galaxy 5.0 Android Player questions...if anyone has one
By Moontrash in forum ComputerReplies: 6Last Post: 23rd Feb 2012, 06:50
