For many years I've used Studio 10 on a XP machine with Svideo and RAC ports without any trouble. Recently had to convert to new W10 64bit machine. No Svideo or RAC ports available so bought a Eminent 3705 video USB grabber. Problem: for some reason Studio 19 doesn't recognise this video grabber. Anybody out there with ideas to solve this? Both Corel/Pinnacle and Eminent let me down. All suggestions are very welcome!!
Results 1 to 11 of 11
Does it work with the emininent video grabber software or any other third party capture software?
The fact that no software recognizes the device indicates that there may be a problem with the drivers. Did you check Device Manager to make sure that the Eminent 3705's drivers installed correctly?
Press Windows+R to open Run. Type "devmgmt.msc" and click the OK button. Look for the device under "Sound video and game controllers". There should not be any triangular icons beside the name used for the device if the drivers installed correctly. If there is no capture device listed under "Sound video and game controllers" look under "Unknown device". If your device is listed there, the drivers did not install. -
If the Arcsoft software works fine then the Eminent 3705's drivers installed correctly. Your device encodes using software so is likely to work with other capture software too. You might try MPC-HC. Click View->Options and then select "Capture" under "Playback" in the left hand pane. Select "Analog" then look for your device under "Video" to see if the Eminent 3705 is detected. If it is, then I'm not sure why Pinnacle Studio 10 can't see it.
Your replies weren't posted when I typed the my previous posts, but it might be worth trying to set up MPC-HC to see if you can get a picture. Its ability to capture is limited, but it isn't hard to set up. (Select the Eminent 3705 under "Capture" above, then click File->Open Capture, to select grabber connections using the "Video" and "Audio.) If you can use MPC-HC to view the input from the Eminent 3705, then there are probably options other than Studio 19 available to you.
Unless Pinnacle has crippled Studio 19 so that it only works with their Dazzle product line, I don't know why it can't see your Eminent 3705. -
Having traced every entry on the internet related with Studio 19 I found out that hidden in the small print Pinnacle will only allow connection via their own Dazzle line USB grabber products!! Now I'm either forced to buy one of their Dazzle products or have wasted my money on buying Studio 19 since it won't work with any third party USB grabbers. Shame on Pinnacle for not stating that clearly when buying (or upgrading to) Studio 19! I'm now inclined to find other similar software that doesn't force me to buy 'their own' grabber. I'm also realy disapponited with their "Studio Backlot" tutorial where this same event isn't mentioned. Really, really disappointed with what Corel offers. I used to be a avid fan of their, perhaps slightly non-conformitive, software but it has all gone down the drain now. They've lost a fan!
P.S.,
Very much thank you to all you guys trying to help me. Really much appreciated!! Sorry it didn't work out. -
P.P.S,
Any suggestions for other software which allow third party video USB grabbers are wellcome!!!! -
EasyCAP003 USB Video Grabber - Ulead Video Studio
By syspolpl in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2015, 04:19 -
Corel Video Studio Pro x4 has stopped working?
By TheKillerQueen in forum Capturing and VCRReplies: 6Last Post: 24th Mar 2012, 13:49 -
2.0 USB Video Grabber
By newman2 in forum Capturing and VCRReplies: 1Last Post: 4th Jan 2012, 02:15 -
which multi-channel video grabber hardware to use?
By mars1412 in forum Capturing and VCRReplies: 5Last Post: 22nd Jun 2011, 10:51 -
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 01:02
