Novice user of Avidemux 2.6.10, downloaded from this site.
I have a 530gb AVI file, raw capture using Amarectv and the Avermedia C027 hdmi capture card. Avidemux does not open this huge file! The first frame is showing all green on the preview screen. Down at the bottom showing P-FRM (01)
Funny thing is that my very first time i opened this file, it did open but at some frame a little ahead of the very beginning. I then tried to encode but kept getting errors which I did not write down (wish I had).
First things first, how to make Avidemux recognize the file? I even unistalled and reinstalled avidemux but that did not help, same negative result.
if this helps, here is the media info:
General
Complete name : E:\New folder\FILE.avi
Format : AVI
File size : 530 GiB
Duration : 3h 44mn
Overall bit rate : 337 Mbps
Video
Format : YUV
Codec ID : ULY2
Codec ID/Info : Ut Video Lossless Codec
Codec ID/Hint : Ut Video
Duration : 3h 44mn
Bit rate : 323 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 fps
Color space : YUV
Chroma subsampling : 4:2:2
Compression mode : Lossless
Bits/(Pixel*Frame) : 5.840
Stream size : 507 GiB (96%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 3h 44mn
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 2.41 GiB (0%)
Alignment : Aligned on interleaves
Try an older version of avidemux. Maybe 2.6.8. https://www.videohelp.com/software/AviDemux/old-versions#download
Or use something else like virtualdub.
Or are you just going to convert? -
it's a 530gb file which I want to convert to something VideoRedo can recognize as VRD does not recognize AVI. I then want to burn onto a BD-R.
This will require file reduction obviously. I used handbrake at 15000kb/s to make it about a 23gb file, great quality, but VRD did not recognize that file either even though VRD does deal with h264 / mp4 files (this is another topic with a rare vrd error "Unable to determine initial clock, details in the log file"). (problem is I don't seem to have a vrd log file at all in c\users\appdata\roaming - but VRD still works on an mpeg2 files, so I know VRD does indeed work on this pc.
the 23gb handbrake file has commercials which I want to edit and remove. Otherwise I am able to author this 23gb file with multiavchd and burn to bdr with imgburn. So my problem is editing which I can approach in 2 ways (1) reduce the 530gb file to some format that VRD can recognize or (2) find an editor that will recognize my somehow unreadable 23gb h264 file.
I was hoping that avidemux would work since I that can reduce file size.
I tried avidemux on the 23gb h264 file too with the following error (after a brief test edit) - "the video is in copy mode with cut points on key frames" - but it did work as I did a Video (copy) and Audio (copy) but set Output format to MP4. Noticed a slight audio sync issue, what a disappointment.
VRD still did not recognize this output file though. However, avidemux can edit but seems a very tedious task since it seems to require multiple manual edit commands for each edit (vrd can do it all in one swoop).
The error also warned of corruption which i suppose would be encountered on playback in the Bluray player.
Is the AmarecTV the best HDMI capture software?
By Stears555 in forum Capturing and VCRReplies: 1Last Post: 19th Dec 2015, 13:47 -
No Compression / no raw avi with Enutv 2 capture card
By POP1 in forum Capturing and VCRReplies: 3Last Post: 26th Mar 2015, 19:34 -
AmarecTV Won't capture with any device I try
By Shilaly in forum Capturing and VCRReplies: 12Last Post: 4th Feb 2014, 09:25 -
Win8/64bit Video Capture Card That Captures Raw AVI
By Involuntary in forum ComputerReplies: 16Last Post: 27th Dec 2013, 13:47 -
amarectv and roxio game capture hd pro
By crazycoyote in forum Capturing and VCRReplies: 5Last Post: 24th Nov 2013, 16:34
