I am not sure if is just this program/some/all, but one should not have to go through registry to remove old version after updating.
I like how this program is already in right click menu on a movie file. B/c otherwise it would be a pain in the rear. Why do the .dll have to be in the same dir. as the app. I should be able to copy app, or make shortcut to another folder. Instead of going into program files or moving the whole folder. Also when installing file, it says missing rundll32, or something to that effect. Although program works fine when using sub menu on a file.
Langley claims I am one of the most intelligent people on the planet, since when do they ever tell the truth.
There's a portable version of MediaInfo you can just download, unzip and run. Is that what you're using? It'll offer to add a MediaInfo shortcut to the right click menu the first time you run it. The Options/Preferences menu lets you remove the menu item or restore it again.
To be honest I don't understand the "dll have to be in the same dir. as the app" problem. Why do you need to move the program files folder around?
You can create a shortcut to MediaInfo.exe and put it in the Windows SendTo folder if need be. Then you can right click on any file and select SendTo/MediaInfo.
Rundll32.exe is a Windows system file. For XP it lives in the C:\WINDOWS\system32 folder.
http://blog.nirsoft.net/2009/09/17/how-to-extract-missing-system-files-from-the-dvd-of...indows-7vista/
https://support.microsoft.com/en-au/kb/812340Last edited by hello_hello; 4th Dec 2015 at 12:49.
What Version Of MediaInfo To Use?
By MOVIEGEEK in forum Software PlayingReplies: 58Last Post: 1st Jun 2015, 08:43 -
mediainfo 773
By mysts in forum EditingReplies: 2Last Post: 13th Apr 2015, 19:37 -
MediaInfo CLI - C#
By Keller501 in forum ProgrammingReplies: 12Last Post: 30th Jan 2014, 21:57 -
Gspot vs Mediainfo
By Creed92 in forum Newbie / General discussionsReplies: 25Last Post: 23rd Jun 2013, 13:12 -
MediaInfo : what does this figure mean?
By Bonie81 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2011, 22:22
