I get an error when trying to cut an mpg file in windows xp. Before I was able to get passed the error and cut but now windows closes tmpg. Anybody have a work around.
jokerman, see the post a bit higher up the list made by doot.
He and I have the exact same problem. The common thread seems to be Windows XP.
I was about to go get another program to do my editting, but maybe it's time to reload with Win2K and give that a go. -
I use windows XP and have not had any problems. Dont know if that really helps anyone. What version of Tmpg are u using? I use version 12b.
I'm using 2.5.3. I have 12a I think but haven't tried it yet.
Are your cuts precise? That is, when you pick a spot in the preview window, is that where it cuts the video for you? Mine are off by 30 seconds to several minutes, cutting MPEG2 files. -
I just posted to the other thread that I tried taking out my suspect cheap memory and got the same error message. I tried v2.5.3 and 12a and got the same message.
I now think it's an issue with WinXP on some systems. At least for me it still does the work, just gives me the message. -
I've had exactly the same problem. I've found that not only are the cuts extremely imprecise (off by several seconds), but when I cut, the audio cuts where i told it to, but the video keeps going for several seconds. I discovered this after I tried to merge 2 mpegs that each had this same error in cutting; the missing audio at the end of the first clip was filled in by the beginning audio from the second. Therefore, the total missing audio at the end of the merged clip was equal to the sum of the missing audio at the end of each seperate clip before merging.
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 01:11
