I have several home videos that are in .avi format (each are 2 hours in length) that I want to burn to a DVD and add chapters. I am fairly new to this stuff, so I'm posting here because I'm not sure which category this fits into. I want to keep the best quality possible when burning to the DVD.
In reading the forms it sounds like IMGBurn is a good software to use when burning the DVD. Will that take .avi files or do I need to encode those before burning? If so, what software is best for that or works best with IMGBurn and what format does IMGBurn need make the DVD?
Then I want the DVD to have chapters. Is there a software that detects the dead space in between home video clips and automatically makes those into chapters? If so, what is that software? If not what is the best authoring software that is easy to use to put chapters in manually in the selected dead spaces? Thanks in advance!
Results 1 to 12 of 12
If you want to have any semblance of quality left, forget about putting more than 1 of those 2-hour clips to each disc. Which may make the whole chapter thing moot.
Scott -
Yes, I plan on putting one 2 hour tape onto each DVD. But within the 2 hour clip there are places where the camera was turned off and restarted. I'm wondering if that can be detected automatically or if that is a manual process to find the dead space and create chapters at each of those spots?
Setting specific spots for chapters in AVStoDVD is not simple. It normally puts chapters at 5 minute intervals. There is a function called Seek Chapters in AVStoDVD, but I don't know how well it works. You might try it. To do so, import your video, then click on the gear icon on the right side of the main screen in AVStoDVD. This brings up a new window, with several tabs, so click on the Chapters tab. Remove the check mark from the Auto Chapters, which will allow you to manipulate chapter marks.
By the way, AVStoDVD no longer comes with ImgBurn in the install package. You'll have to install it separately. -
Installation should take just a minute or two. Did you use the direct link download on this page? https://www.videohelp.com/software/AVStoDVD
Now it worked. I didn't realize it was waiting for me to run the filter install. Thanks for your help!
Author DVD using different format videos
By thumb in forum Authoring (DVD)Replies: 12Last Post: 21st Sep 2015, 18:38 -
What format do you convert your videos to?
By johns0 in forum PollsReplies: 14Last Post: 18th May 2012, 07:57 -
change aspect ratio & convert m2ts files & brighten videos
By rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 08:34 -
How to fix incorrect time? MKV rip displays as 14+ hrs long in all players
By elcoyoteloco in forum Video ConversionReplies: 2Last Post: 6th Feb 2011, 13:11 -
Best video format for long term storage of home movies
By Airjrdn in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2011, 17:14
