Hi,
although some of it is old news, I'd like to mention here some free VirtualDub filters developed this year:
1. Film Dirt Cleaner. It's a motion-search-based denoiser that finds similar blocks in both neighbor frames (using motion flow) and if they look more like each other than the current block, it uses them to clamp values inside the current block, eliminating spots and noise. When the frames are too different, an intra-frame degrain method is used to fight little spots. See some before/after animation here:
http://www.infognition.com/dirtcleaner/
The logic is inspired by RemoveDirtMC() from AviSynth that used RemoveDirtSSE2.dll and RemoveGrainSSE2.dll plugins together with mvtools. This VirtualDub filter is a fresh implementation that does not rely on any of those tools or plugins. On multicore PCs it works faster than AviSynth version in my tests, although still not too fast.
Requires VirtualDub 1.9.1 or newer.
2. Intelligent Brightness
This filter automatically adjusts brightness/contrast to bring dynamic range to specified bounds. This is similar to AutoLevels but it does not change white balance (colors remain intact, only brightness changes), and it fights noise amplification and flickering by using different target ranges for dark scenes and using temporal smoothing for its parameters. Target range becomes content-sensitive and you can control it by changing its defining curve in settings dialog.
A little comparison with AutoLevels and MSU Smart Brightness:
https://www.youtube.com/watch?v=zkj5yGLhs8k
Homepage with more descriptions and download:
http://www.infognition.com/brightness/
These two filters were created for (and in active collaboration with) one client who does 8-mm film restoration professionally.
3. (possibility)
Recently we made a simple one-pass deshaker:
https://www.youtube.com/watch?v=puGY1JJ1Los
http://www.infognition.com/blog/2015/deshaker.html
It buffers up to 50 frames, analyses motion and straightens global motion making it mostly linear. It only deals with translational motion, so it does not fix rotations or in-frame distortions. It's much simpler than Gunnar Thalin's Deshaker however it does its work in single pass which might be important for some folks tired of two-pass processing.
Currently it's part of our SDK but we're thinking of making it a VirtualDub filter. I just need to hear whether it's worth it, do you guys want such a filter?
I rather like Film Dirt Cleaner, which I use for Super 8 film restauration.
But I would welcome a switch to de-activate Degrain. I find that very often, that feature generates loss of detail in my particular usage.
Best regards,
Patrick
from Brittany in France
VirtualDub Deshaker Question
By rbjunior in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2015, 14:36 -
[Avisynth/VirtualDub] Need help removing Dust/Dirt clouds from film.
By LaKap in forum RestorationReplies: 4Last Post: 30th Sep 2014, 10:49 -
Virtualdub filters For 8mm Film That Was Captured On Vhs
By avz10 in forum Capturing and VCRReplies: 108Last Post: 27th Jun 2013, 10:31 -
VirtualDub/Deshaker trouble
By she-ra in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2012, 08:12 -
Virtualdub with Deshaker problem
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2011, 09:39
