Hi, I've noticed that it can be quite a jungle when picking the right software.
I've got just couple of criteria:
1: do cuts
2: export at sources resolution
That's all. The problem I found is that you're often boxed into a ratio resolution, 4:3 and so on, which compresses and changes the the image quality.
The formats that I'm importing are, vob, mp4, avi, wmv, flv. The export can be what ever, but preferably mp4.
I love using HandBreak, but it does not support splitting, so i need something that does.
Considering the low amount of criteria there should be a free or cheap alternative.
Oh, and I have tried Lightworks and Wondershare Filmora, both does not support source resolution output.
Thanks, Ill give it a try.
Also after trying VirtualDub i stumbled upon Avidemux, which is based on VirtualDub.
I must say that Avidemux is really good, but you need to know the basics of audio/video encodings.
Video editing software advice
By zoink187 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2013, 06:11 -
Medical project needs advice for software choices
By shokan22 in forum Newbie / General discussionsReplies: 11Last Post: 26th Aug 2013, 10:54 -
Advice on which software to use
By eeyvnmj in forum DVD RippingReplies: 4Last Post: 21st Jun 2012, 13:53 -
Advice on Conversion software
By tcory in forum Video ConversionReplies: 7Last Post: 22nd Sep 2011, 22:19 -
Software Advice Wanted
By CthulhuSaves in forum DVD RippingReplies: 3Last Post: 16th Feb 2011, 13:25
