  1. Hello,
    I have access to a list which contains many IPTV channels. If I play one of them, it only lasts few second and then crashes.
    What is the problem? Can anyone help?
    Regards!
  2. Member NiGHT-WiNG's Avatar
    May 2015
    Some sort of cave with bats flying around
    Are you able to share this list to help abit more as we can't just magicly work it out because many things could be the problem for example the stream might have limited bandwith on it or you could be having cache problems.
