Every time I encode a 720x480 DVD vob to MKV oR MP4 in XviD4PSP, the encoded size of the vid is 720x536. I tried changing the encoding codec to "Copy" but what it outputs is completely unusable (tiny video with same file size.)
Does anyone know how to set the encoding options for MP4 or MKV so the output is the same size as the source?
Thanks,
KD
It does tend to remove the black bars for me, too. But copy shouldn't be changing anything; maybe there's something wrong in your setup or settings. Have you checked what it's doing by opening Video on the top toolbar and then Resolution/Aspect? (This doesn't apply in Copy mode.)
What version are you using? 5.0.xxx?
But yep check the resolution/aspect from the menu.
Xvid4PSP - presets and file size
By NDMMackay in forum Video ConversionReplies: 6Last Post: 28th Feb 2014, 03:24 -
File size issue after converting videos with XviD4PSP 5~
By Needles in forum Newbie / General discussionsReplies: 4Last Post: 8th Oct 2013, 07:55 -
Encoding with XviD4PSP~
By Needles in forum Newbie / General discussionsReplies: 8Last Post: 1st Sep 2013, 20:36 -
Xvid4PSP Encoding Modes
By leghorn in forum Video ConversionReplies: 2Last Post: 4th Dec 2012, 04:14 -
Is there a way on how to shutdown xvid4psp after encoding?
By mark63534 in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2011, 23:05
