  1. Can PotPlayer show colored text? I mean in subtitle, during a movie play. What to do in his settings?
  2. Member darkknight145's Avatar
    Feb 2007
    Australia
    Right click potplayer, select preferences, select subtitles menu and expand , select Font Style. You can then play with many different setting including fonts and colours.
  3. I have colored lines in subtitle, like
    7
    00:02:09,347 --> 00:02:16,107
    <font color=#00FFFF>Stenfordov zatvorski eksperiment</font>
    and wish to see that color during play. What to do?
  4. Most players don't pay any attention to attributes in SRT subs.
  5. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Just installed the latest version 1.6.56815 and had 1.6.56209. Both versions of Potplayer shows colors in SRT and SSA/ASS fomats. As Jagabo correctly pointed out, most players do not honor attributes for SRT but fortunately Potplayer recognizes most:
    00:00:01,459 --> 00:00:05,149
    <B>Bold</B> And not bold
    <font color=#00FFFF> Green BLue??</font>
    [Script Info]
    ; This is a Sub Station Alpha v4 script.
    Title: VirtualDub 'subtitler' filter demonstration
    Original Script:
    ScriptType: v4.00
    Collisions: Normal
    PlayResY: 240
    PlayDepth: 0
    Timer: 100.0000
    [V4 Styles]
    Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, TertiaryColour, BackColour, Bold, Italic, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding
    ;Style: Foo,MS Gothic,72,65535,65280,65535,0,0,-1,1,2,4,2,30,30,30,0,128
    Style: MainB,Arial,14,65535,255,0,0,0,-1,1,2,4,1,16,16,16,0,0
    Style: MainT,Arial,14,65535,65280,65535,0,0,0,1,2,4,5,16,16,16,0,0
    Style: Timer,Arial,14,65535,65280,65535,0,0,-1,1,2,4,5,16,16,40,0,0
    Style: B0S0K,Arial,14,&HE0E0E0,65280,65535,&H000000,0,-1,1,0,0,5,16,16,40,0,0
    Style: B2S2R,Arial,14,&HE0E0E0,65280,65535,&H004080,0,-1,1,2,2,5,16,16,40,0,0
    Style: B2S6G,Arial,14,&HE0E0E0,65280,65535,&H408000,0,-1,1,2,6,5,16,16,40,0,0
    Style: B4S4B,Arial,14,&HE0E0E0,65280,65535,&H804000,0,-1,1,4,4,5,16,16,40,0,0
    Style: Karaoke,Arial,14,&H40FFFF,&HFF4040,65535,0,0,0,1,2,4,5,16,16,16,0,0
    Style: ShiftJIS,MS Gothic,20,&HE0E0E0,65280,65535,0,0,0,1,2,4,5,16,16,16,0,128
    Style: BoxT,Arial,14,65535,255,0,0,0,0,3,2,4,5,16,16,16,0,0
    Style: BoxBold,Arial,14,65535,255,0,0,-1,0,3,2,4,5,16,16,16,0,0
    [Events]
    Format: Marked, Start, End, Style, Name, MarginL, MarginR, MarginV, Effect, Text
    Dialogue: Marked=0,0:00:00.00,0:00:03.00,MainB,,0000,0000,0000,!Effect,{\q1}Shadows and borders\N\NYou can vary the depth of the translucent shadow as well as the thickness and color of the border.
    Dialogue: Marked=0,0:00:00.00,0:00:03.00,B0S0K,,0000,0000,0000,!Effect,Border=0, shadow=0
    Dialogue: Marked=0,0:00:00.00,0:00:03.00,B2S2R,,0000,0000,0030,!Effect,Border=2, shadow=2 (red)
    Dialogue: Marked=0,0:00:00.00,0:00:03.00,B2S6G,,0000,0000,0060,!Effect,Border=2, shadow=6 (green)
    Dialogue: Marked=0,0:00:00.00,0:00:03.00,B4S4B,,0000,0000,0090,!Effect,Border=4, shadow=4 (blue)
    Dialogue: Marked=0,0:00:00.00,0:00:03.00,BoxT,,0000,0000,0090,!Effect,Opaque Box Marque
    Dialogue: Marked=0,0:00:00.00,0:00:03.00,BoxBold,,0000,0000,0090,!Effect,Opaque Box Bold Marque
    MAKE SURE NO COLOR IS NOT CHECKED:
Name:	No Color.jpg
  6. Thanks, Budman1. I forgot how to put SOLVED on this.
  7. DECEASED
    Jun 2009
    Heaven
    That's not good
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    You can add [SOLVED] to the end of your thread title if you like. Just click on Edit and Go Advanced in your first post to edit it.
