  1. hi everyone,
    i tried to convert MKV videos to AVI and MP4 using MOVAVI video converter but i got a strange error when playing these output videos in some machines only, i dont know what should i do to avoid this problem, i have a printscreen to show you and info file too:
    General
    Complete name : C:\Users\Administrator\Videos\Movavi Library\Video.avi
    Format : AVI
    File size : 411 MiB
    Duration : 49mn 20s
    Overall bit rate : 1 166 Kbps
    Writing application : Lavf56.36.100
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L1
    Format settings, BVOP : No
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : FMP4
    Duration : 49mn 20s
    Bit rate : 1 025 Kbps
    Width : 720 pixels
    Height : 404 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.141
    Stream size : 362 MiB (88%)
    Writing library : Lavc56.41.100
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 49mn 20s
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 45.2 MiB (11%)
    Alignment : Aligned on interleaves
    Interleave, duration : 40 ms (1.00 video frame)
    I hope i can get some help as soon as possible
    Thank you
    Have you tried any other converter? Handbrake, Xmedia Recode, MKV2MP4.
  3. Thank you for your reply Rick
    i've tried different applications, and i've got the same problem with ANY VIDEO CONVERTER and Bigasoft Total Video Converter, sometimes i got the idea that maybe this comes from my computer, i've even tried two of the softwares you gave me still the same problem, this is weird i know, thank you anyway
    I guess you have tried play them with different players also? Like vlc media player?
    And is that mediainfo report from a source file? Or something you have converted to? Because you say you want to convert mkv to mp4/avi...and that is an avi. Post the details from the source file.
  5. it doesnt work other than VLC media player, as you know vlc can play any video file but in other players like potplayer, gomplayer or media player i get the problem, this report is from a converted video, and this is the source file report
    Général
    Identifiant unique : 325787373442735428422557412313530926623 (0xF5185DA52D83DF4D5BDE4348EEC8861F)
    Nom complet : E:\video.mkv
    Format : Matroska
    Version du format : Version 2
    Taille du fichier : 911 Mio
    Durée : 49mn 20s
    Débit global moyen : 2 582 Kbps
    Application utilisée : mkvmerge v1.0
    Bibliothèque utilisée : mkvmerge v1.0
    Vidéo
    Format : AVC
    Profil du format : High@L4.1
    Paramètres du format, CABAC : Oui
    Paramètres du format, RefFrames : 5 images
    Identifiant du codec : V_MPEG4/ISO/AVC
    Durée : 49mn 20s
    Débit : 2 147 Kbps
    Largeur : 1 280 pixels
    Hauteur : 720 pixels
    Format à l'écran : 16/9
    Type d'images/s : Constant
    Images par seconde : 23,976 Im/s
    Espace de couleurs : YUV
    Sous-échantillonnage de la chrominance : 4:2:0
    Profondeur des couleurs : 8 bits
    Type de balayage : Progressif
    Bits/(Pixel*Image) : 0.097
    Taille du flux : 758 Mio (83%)
    Bibliothèque utilisée : x264 core 148 r2638 7599210
    Paramètres d'encodage : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Langue : Anglais
    Default : Oui
    Forced : Non
    Gamme de couleurs : Limited
    Coefficients de la matrice : BT.709
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Extension du mode : CM (complete main)
    Paramètres du format, Endianness : Big
    Identifiant du codec : A_AC3
    Durée : 49mn 20s
    Type de débit : Constant
    Débit : 384 Kbps
    Canaux : 2 canaux
    Position des cannaux : Front: L R
    Echantillonnage : 48,0 KHz
    Mode de compression : Avec perte
    Taille du flux : 136 Mio (15%)
    Default : Oui
    Forced : Non
