The script below demuxes the video, normalizes the AAC then converts the audio to AC3 and remuxes as a .ts file. It also gives me a separate normalized AAC file. Instead of that, I have an MKV with AAC that I'd like to just normalize preferably without having to demux and remux. If not possible then demuxing and remuxing is fine. Can anyone help with a script please. Thanks
Code:"X:\Portable Installations\MKV Toolnix\mkvextract.exe" --ui-language en tracks %1 0:"video.h264" 1:"gain0.m4a" "X:\Portable Installations\ffmpeg\bin\ffmpeg.exe" -i "gain0.m4a" -vn -c:a copy -absf aac_adtstoasc "gain.m4a" "X:\Portable Installations\AAC Gain 1.9\aacgain" -r -k -m 0 gain.m4a "X:\Portable Installations\ffmpeg\bin\ffmpeg.exe" -i gain.m4a -map 0:0 -vn -c:a copy "%~d1%~p1%~n1.aac" -map 0:0 -vn -c:a ac3 -b:a 192k "output.ac3" SET tsmuxer="X:\Portable Installations\tsMuxeR_1.10.6\tsMuxeR.exe" echo MUXOPT --no-pcr-on-video-pid --vbr --vbv-len=500 > remux.meta echo V_MPEG4/ISO/AVC, "video.h264", insertSEI, contSPS >> remux.meta echo A_AC3, "output.ac3" >> remux.meta %tsmuxer% remux.meta "%~d1%~p1%~n1.AC3.ts" DEL /Q remux.meta del gain.m4a del gain0.m4a del video.h264 del output.ac3 "X:\Daves Folder\Sounds\VideoRedo Completed Sound Short.WAV" pause
Linux command line to normalize wav's in mkv video clips.
mkdir NORMALIZED; for mkv in *.mkv ; do wav=`basename "$mkv" .mkv`.wav; echo "${wav}"; ffmpeg -i "${mkv}" -acodec copy "${wav}" ; normalize-audio "${wav}"; ffmpeg -i "${mkv}" -i "${wav}" -codec copy NORMALIZED/"${mkv}"; done;
It might be adjusted to mp4, avi... mp3...
Need help with TS Muxer Batch Script
By VideoFanatic in forum Video ConversionReplies: 31Last Post: 29th Sep 2015, 18:40 -
A batch/Python script to Mux subtitles with video
By Scavvy in forum ProgrammingReplies: 4Last Post: 6th Jul 2015, 03:23 -
Avidemux Batch Script
By Haukeluet in forum Video ConversionReplies: 8Last Post: 13th Feb 2015, 15:28 -
AviDemux batch script
By jakhazell in forum Newbie / General discussionsReplies: 5Last Post: 21st Aug 2011, 21:16 -
script batch to extrack audio from DVD
By kevotinh in forum DVD RippingReplies: 0Last Post: 19th Mar 2011, 18:24
