Appreciated members,
I need to know what is the best way to introduce resources in Encore CS6. I know three ways:
1º- From Premiere project export to Encore.
2º- Being in Encore, import the Premiere project.
3º- Being in Encore, import the finished video file, such as a full HD mp4.
The first two ways are actually the same, and there should be no difference. The difference might be between 2º and 3º. I've tried both ways and I didn´t notice the difference in quality, but I suppose it will not be the same. I´m wondering what should be theoretically the best format to import in Encore, is the Project or Video finished ?.
Thanks in advance.
Authoring VCD???
Nope. I'm moving you to our general video section. -
It depends on what kind of file you export from Premiere.
Assuming you are using the Adobe Encoder and outputting a BR compatible file (one that Encore does not need to re-transcode) there should be no difference at all.
"Full HD MP4" however, will generally require re-encode and will lose some quality.
DVB-T2: H.265 (HEVC) introduction
By ricardo.sander in forum DVB / IPTVReplies: 3Last Post: 28th Jul 2014, 08:24 -
h264 encoding does not use all system resources
By sharkbite in forum Video ConversionReplies: 3Last Post: 28th Feb 2012, 19:16 -
Resources Needed to Remove DRM From Video
By Rogcliff in forum Newbie / General discussionsReplies: 1Last Post: 2nd Sep 2011, 18:39 -
General Introduction to Lightworks
By tin2tin in forum User guidesReplies: 0Last Post: 19th Aug 2011, 16:05 -
Sharing resources between htpc and my desktop
By Haopengyou in forum Media Center PC / MediaCentersReplies: 3Last Post: 3rd Apr 2011, 09:37
