i always thought the higher the video bitrate the better. but how come in this link the bottom image 2850 kbps's color looks more vibrant? The top picture is 3400 kbps but the color looks more washed out?
http://imgur.com/a/hHtks
is the second image's quality better than the first?
Bitrate should'nt have any bearing on color changes but instead mostly on detail retention. Certainly would never get that level of hue shift between encodings. Certainly something else caused this.
One of the encodings may of used bad decoder settings, which then passed on the image to the encoder. Or it was made "more vibrant" on purpose by the person encoding it. Assuming both encoding came from the same source, like a Bluray.
In the future I would suggest http://screenshotcomparison.com/ instead of imgur for comparing.
If the goal is to be as close to the source as possible, then that an impossible task without a source image for comparison. One of them is obviously wrong. Looks like a BT.601 BT.709 problem, and the "more vibrant" one is wrong with its crushed blacks.is the second image's quality better than the first?Last edited by KarMa; 25th Nov 2015 at 04:10.
oh you are right. I did not noticed the crushed black until you mentioned it. Could not see the details in the black sweater on the bottom picture. But i did not realized crushed black would make other colours look better though..
Generally, if a file with a lower bitrate looks better than one with a higher one, whoever did the former did a better job encoding. There is a hell of a lot more to it than just bit rate. I've seen video with a bit rate of >5mps that looked awful.
What encoder was used? I could imagine something like 1080p or 720p content, encoded with x264 at 2850kbps, would look a lot better than an older encoder like MPEG-2 at 3400kbps.
Wav files with 1411 kbps and 1536 kbps.
By SyncroScales in forum AudioReplies: 8Last Post: 17th Jan 2015, 04:37 -
problem exporting 320 kbps audio bitrate
By mediatuch in forum EditingReplies: 13Last Post: 29th Oct 2014, 14:14 -
Getting top quality Kbps from streams using variable bitrate screen control
By jilly in forum Video Streaming DownloadingReplies: 7Last Post: 1st May 2014, 16:42 -
Sony Vegas - 320 kbps vs 192 kbps
By CrystalMethod in forum AudioReplies: 4Last Post: 7th Mar 2014, 18:16 -
Authoring DVD Tools with maximum bitrate 640 Kbps of AC-3
By wisitch in forum Authoring (DVD)Replies: 9Last Post: 8th Nov 2012, 13:59
