  1. Member vhelp's Avatar
    Mar 2001
    New York
    solved
    Anyone know how I can log out of my google account in chrome ?
    I'm on my laptop. And I don't remember how or when I logged into google (it always shows my name at the top) and I want to sign out, but there is no provision to do so. I want to sign out of it so that I can sign in with another google account. I created another google account. Thank you.
  2. Member vhelp's Avatar
    Mar 2001
    New York
    solved -- Never mind. I found it. You have to click on the icon at the top right and select sign out. Then, there's another page where you scroll to the bottom and select the link that says "sign in with a different account", and then select link "Add account". The rest is easy.
  3. Member vhelp's Avatar
    Mar 2001
    New York
    new question..
    Can I sign in to two accounts in google on my windows laptop ? I want to juggle between the two emails, and google forum groups without having to log out and sign in to each. That would be a pain. Or even worse, if i had to keep both android tablets with me and juggle between two. After all, its very difficult to type on and i would not be able to post screenshots to the emails. But on the windows laptop, when signed into google, i can do that.
  4. Yes on different browsers
    for example you can login on Firefox to second account
  5. Originally Posted by roma_turok View Post
    You can do it with Firefox alone. Sign into one account as normal. Then open a Private tab and log into the second account.
    As above.
    Firefox on Android has private tab function too. So you can log into 2 accounts on one android device.
  6. Yea but his wanted always login connect
    what happens when his close private tab?
    as far I know login not saved in private mode
