Hello,
I am trying to convert uncompressed Lagarith film to x264, but I am experiencing weird color issues.
http://screenshotcomparison.com/comparison/151700
Here's my command line:
x264 --pass 1 --bitrate 25000 --bluray-compat --level 4.1 --preset slow --tune grain --keyint 24 --sar 1:1 --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --b-pyramid none --weightp 0 --colorprim bt709 --transfer bt709 --colormatrix bt709 --merange 24 --stats ".stats" --opencl --output NUL "morfina.avs"
x264 --pass 2 --bitrate 25000 --bluray-compat --level 4.1 --preset slow --tune grain --keyint 24 --sar 1:1 --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --b-pyramid none --weightp 0 --colorprim bt709 --transfer bt709 --colormatrix bt709 --merange 24 --stats ".stats" --opencl --output "morfinaa.264" "morfina.avs"
Any suggestions? Ideas?
				Results 1 to 15 of 15
	.avs
 AviSource("avs_1.avi")
 AddBorders(0, 20, 0, 22)
 MediaInfo (It's actually MagicYUV)
 General
 Complete name : J:\avs_1.avi
 Format : AVI
 Format profile : OpenDML
 File size : 331 GiB
 Duration : 1h 51mn
 Overall bit rate : 424 Mbps
 Recorded date : 2015-11-22T08:49:04+01:00
 Writing application : Adobe Premiere Pro CC 2015 (Windows)
 Video
 Format : MAGY
 Codec ID : MAGY
 Duration : 1h 51mn
 Bit rate : 424 Mbps
 Width : 1 920 pixels
 Height : 1 038 pixels
 Display aspect ratio : 1.85:1
 Frame rate : 24.000 fps
 Bits/(Pixel*Frame) : 8.856
 Time code of first frame : 00:00:00:00 / 00:00:00:00
 Time code source : Adobe tc_A / Adobe tc_O
 Stream size : 331 GiB (100%)
	Looks like one decoder expanded to PC scale, the other kept it at TV scale.
	Problems like this are never caused by x264. There's more going on here than just PC/TV levels and rec.601 vs. rec.709 matrix issues. The graphics card's video proc amp settings are probably "enhancing" one of the images and not the other. How was each image produced? What was your AviSynth script?
	Avisynth Script:
 VirtualDub image was made by loading the upper AviSynth script and exporting that exact frame through VirtualDub as well.
 The second one was made using PotPlayer (when the original avs_1.avi has normal colors).
 Input is in RGB, and I want to convert it for Bluray playback. Got any ideas?
	Change your AviSynth script to
 Encode that as before. Then use an AviSynth script to view the resulting h.264 video:Code:AviSource("avs_1.avi") AddBorders(0, 20, 0, 22) ConvertToYV12(matrix="rec709")
 Compare the colors and levels to the original. They should be the same. Note that VirtualDub almost always uses a rec.601 matrix to display video in its preview panes. So you will see the wrong colors if you open the encoded video directly in VirtualDub (or leave out the ConvertToRGB(matrix="rec709")). Actually, try doing this with the file you've already encoded. It might be OK as it is.Code:ffVideoSource("morfinaa.264") ConvertToRGB(matrix="rec709")
 Keep in mind that Potplayer may not be displaying the correct levels and colors depending on the output device selected and your graphics card's video proc amp settings.Last edited by jagabo; 24th Nov 2015 at 12:27.
	Video encoded with ConvertToYV12 has still the same colors as before (not proper) in PotPlayer, but looks exactly like it should in VirtualDub.
 Any ideas what could I do to make sure this issue won't exist on Bluray player?
	Are you sure that VirtualDub preview is correct, meaning it suppose to look like that? It looks a bit dark to me, those levels that you get at the end seem correct, what you suppose to get playing DVD or Blu-Ray ... Cannot say what is the cause in your case, or if everything is ok basically, just giving an opinion about those levels.
	If he's using my script for viewing the encoded video what he sees in VirtualDub should be the same as the RGB source he started with (except for the expected errors from the RGB to YUV to RGB conversion).
 Of course, we don't know if the RGB source has the correct colors since most sources would have been YUV and we don't know if was converted to RGB correctly.Last edited by jagabo; 25th Nov 2015 at 21:42.
	After tweaking color settings in PotPlayer - it is displaying the correct colors now as well. I had it set to BT.601, changed to BT.709. Also it wasn't set to full color range, so I changed it to full.
 So any ideas how could I make sure this won't exist on Bluray player?
	Players typically assume limited range BT.709 for HD content. Using full range is a good way to get wrong colors. Like jagabo said you cannot trust VirtualDub's preview to show correct colors for BT.709 YUV sources. You can insert "ConvertToRGB(matrix="rec709")" at the end of the script, then do your color tweaking. After you are done with tweaking you have to remove the line again for the actual encoding so that no unneeded YUV->RGB->YUV conversion is done.
	Be careful about what the limited/full range labels mean. On some devices they are referring to the output (the screen), on others the input (the video file). Some devices have settings like high/low -- what the hell does that mean? The international standard for encoded video has the luma ranging from 16 to 235 (limited range). On conversion to RGB (what you see on the screen) it becomes 0 to 255 (full range). SD (eg. DVD) usually uses the rec.601 matrix, HD (eg. Blu-ray) the rec.709 matrix. The colors are slightly different, most visible in greens and reds:
 https://forum.videohelp.com/threads/329866-incorrect-collor-display-in-video-playback?p...=1#post2045830
 Which of those two matrices you use doesn't effect the brightness of greyscale elements.
  x264 Mediainfo to MeGUI x264 SettingsBy Arugen in forum Video ConversionReplies: 2Last Post: 13th Aug 2015, 02:14
  Is this true?Women see less colors than men, and they see washed out colorsBy Stears555 in forum Off topicReplies: 5Last Post: 10th Jul 2014, 14:07
  Full range(0-255)colors of x264 doesn't work in FFMPEG-based softwaresBy Stears555 in forum Video ConversionReplies: 1Last Post: 17th Apr 2014, 10:07
  show x264 command line output when using megui as x264 guiBy codemaster in forum Video ConversionReplies: 4Last Post: 12th Mar 2013, 11:35
  Xvid vs x264 -- Bit Rate: 1900 kbps -- Same quality but smaller x264 file?By kingaddi in forum DVD RippingReplies: 17Last Post: 2nd Sep 2012, 12:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
