    Nov 2015
    Hi I'm trying to cut songs from an dvdfilm I've ripped with handbrake. The original format is letterbox 4:3. When i cut and save clips from that file
    it forces the letterbox format into a widescreen file. The video is still 4:3 Letterbox but when i watch in fullscreen its surrounded with black borders.
    Anyone know if its possible to save clips with imovie and still have the original format? Im using version 10.0.9 iMovie.
    Nov 2015
    I Figured it out.
    USA
    It never hurts to tell other Mac users what you have discovered. It might save them from the same problem.
    And welcome to our forums.
    Nov 2015
    I did it wrong from the beginning. I selected the frames i wanted in my new clip and copied to a new window and then saved. If i saved the selection directly from the main video file it gets saved in its original aspect ratio.
