Have a Sony DVPSR210P that has been set to French language.
I want it to be in English
When I go to Display - Setup icon - Rapide - then hit enter,
but there is no further screen to select English.
Maybe there is another way?
Is there some kind of hard reset for this player?
Any comments are appreciated
Thank you october262.
After some experimenting,
I found if you press the stop button on the remote,
then do the display,
it does do the reset ok.
So problem is solved.Last edited by OldGrampa; 23rd Nov 2015 at 22:29.
Handbrake MKV making my TV reset. HELP!
By SoulBrother in forum DVD RippingReplies: 1Last Post: 2nd Jun 2013, 11:08 -
HELP!! RESET DVD Recorder
By Anonymous4453 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th May 2013, 06:39 -
Samsung c500 reset ***HELP***
By Samsungc500 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Nov 2011, 18:51 -
Hard reset for BDP3000
By alexh110 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Oct 2011, 09:37 -
vsRip will not reset timing
By kenryuakuma in forum SubtitleReplies: 3Last Post: 26th Sep 2011, 17:45
