Hello i have some MP4 files.i need to adjust video color because video bit dark and bit red.
which software should i use ? please help
You can use avidemux as recommended in your last vob/mpg color thread. Load your video, set video codec to mpeg4 avc, click filter and under color try different. If you want better output quality then be sure to use the mpeg4 avc video codec, click configure and you can set the quality(constant rate factor).
And if avidemux fails can you try the free xmedia recode, load your video, set the format to mp4, under video choose Codec mpeg-4 avc, under audio choose Mode: copy and under Filters/preview can you add a color correction filter. CLick add to queue and Encode.
Or make a custom avisynth script together with megui.
Or buy Vegas.
Is it possible to change font colour in SRT files or VLC media player?
By Sulli in forum Newbie / General discussionsReplies: 7Last Post: 29th Aug 2017, 23:47 -
Colour correction/reducing audio noise/feedback
By PCC in forum RestorationReplies: 109Last Post: 7th May 2013, 13:57 -
mp4 file not playing in an application that supports mp4 files
By mindstormer in forum Video ConversionReplies: 2Last Post: 1st Jan 2013, 21:17 -
Colour correction of a NTSC VHS captured via PAL Equipment
By alesco in forum RestorationReplies: 24Last Post: 22nd Jan 2012, 14:46 -
MP4 video correction in audio
By onlygk in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2010, 01:08
