    Apr 2005
    Dover NH
    Hi all,
    I've already processed this clip in VDub with the following AVISynth script:
    Import("C:\Program Files\Avisynth\plugins\sRestore.avs")
    AVISource("TEST.avi")
    ConvertToYV12(interlaced=true)
    QTGMC(Preset="faster")
    Srestore(Frate=19.98)
    AssumeFPS(12)
    Crop(8,0,-8,0)
    LanczosResize(640,480)
    Then I thought there were still some duplicate frames so I ran this script:
    AVISource("TEST 2.avi")
    AssumeFPS(12)
    But the result still seems to have the same duplicate frames - frames 16-17 for example.
    Can anyone verify there are duped frames in this clip, and if so, what should I try next?
    Thanks,
    Bill
  2. Yes, frame 18 is a dupe of frame 17. It wasn't seen as such because the two frames don't have the same 'brightness'. There also seems to be a missing frame between 21-22. You have a crappy source and expect perfection? You might try some deflicker filter to try and even up the brightness before then removing the dupes. Or maybe DeDup or MultiDecimate will do a better job of dupe removal, but you should make it progressive (and maybe progressive 29.97fps) first.
    I don't know what that second script was all about. You used it on the results of encoding with the first script? A waste of time since it was already 19.98fps.
    Apr 2005
    Dover NH
    Show me where I said I expect perfection.
    As I've said several times, I'm brand new to this stuff and I appreciate all the help and patience I've received here.
    But if you don't want to help me anymore, then don't. There's no need to snap at me.
  4. Originally Posted by bvdd View Post
    Yes. And the missing frame manono noted.
    You might try using SRestore with a higher frame rate to remove blended frames, then following up with TDecimate() to remove the duplicate frames. But use an edge map (this eliminates overall brightness from the image) as a test clip for TDecimate():
    Srestore(Frate=29.97) # this should remove the blended frames but leaves duplicates
    edges = mt_edge().GreyScale() # build a map of edges for duplicate frame detection
    TDecimate(edges, clip2=last, Cycle=6, CycleR=2) # decimate to 19.98 fps
    AssumeFPS(12)
    Crop(8,0,-8,0)
    If that leaves too many blended frames try:
    Srestore(Frate=24.975) # this should remove the blended frames but leaves duplicates
    TDecimate(edges, clip2=last, Cycle=5, CycleR=1) # decimate to 19.98 fps
    AssumeFPS(12)
    Crop(8,0,-8,0)
    Apr 2005
    Dover NH
    Thanks, I will try those suggestions.
