hey, im using sony vegas and i want to do something like this:
https://www.youtube.com/watch?v=Ep152idlUUA
im talking about the 2015 in the beginning
thanks!
One way to with masks and layers, with vegas mask generator set to luminance
The 2 layers you are compositing are a "brighter/normal" version, and a copy of that layer, a "darkened" version. You can make the darkened version any way you want (e.g. levels, curves, etc.). In that video , the 2015 numbers are brighter
The mask is a white/black image of areas that determine what areas of the "brighter" versions will be "seen through". 100% White areas show through for a luminance mask, 100% black areas are opaque. Shades of grey are intermediate. So you would make a still image with 2015 white on black.
Track 1 - mask
Track 2 - bright version of video
Track 3 - dark version of video
For Track 1 set track FX and use the mask generator. Set it to "luminance" (Don't worry, you can invert the mask if you get the white/black wrong by clicking "invert"). Set the compositing mode of Track1 to "multiply mask". Then set on Track 2 "make compositing child" of track 1
You can animate track 1's mask event/pan crop by setting keyframes to get the 2015 zoom effect in the video (the numbers appear to enlarge over time)
