    Dec 2008
    I've got some vhs tapes I want to convert using my Pioneer DVD recorder. The recorder has a 3D adjustable comb filter which can either be manually adjusted or one can select the existing presents, of one is named "VHS". Would you recommend I juse use the VHS preset or manually adjust it? And if so does anyone know what kind of settings I should manually select? Thanks!
    Feb 2006
    are these homemade tapes or Hollywood movie tapes??
    Dec 2008
    Things recorded from TV and also Pre-recorded (ie purchased) Hollywood stuff.
    Feb 2006
    the pre-recorded Hollywood stuff tapes will have copy protection that will need to be bypassed in order to copy them.
    ones recorded from tv should be easy.
    Dec 2008
    Copy protection isn't a problem - I just want to know if anyone has experience with this 3D comb filter and what settings they'd recommend
