I have the [TMD] copy of Panic Room (two parts) and it has a bit of a hiss in the soundtrack. So I joinrd the files seamlessly and ripped the sound and used the hiss reduction filter in CoolEdit and attached the audio back to the video. But now I get a strange ring. It sounds like someone hitting a wine glass every few minutes. The ring changes in pitch everytime it does it. I've tried editing the sound again in CoolEdit bit I haven't been able to get it out. Does anyone know what my problem is and how to fix it?
Still haven't figured out what's wrong with it. I'm beginning to think it was in the soundtrack of the copy to beging with and my cleaning it up made it more noticeable.
If your copy of CoolEdit is not registered and is a demo, the ringing is there way of telling you it's time to buy it.
Is there anyway I can remove it without having the full version? If I do get the fullversion can I get rid of it then?
Nope... getting the full version is the only way to get rid of this. Plus, you will have to redo the ENTIRE audio file. You might try to find Cool Edit 95 somewhere. This doesn't have the audio plugin tools, but it does have some simple hiss removeal stuff (and doesn't put the "bell" in the audio).
Hey, Im having the same room with Panic Room. Its CD1 and CD2 mpegs and I want to get rid of the hiss. You do you rip the audio from the mpeg?
And you guys are talking about CoolEdit 2000 right?
Audio Hiss Problem--I tried audacity
By bbbbbbb45 in forum AudioReplies: 16Last Post: 15th Apr 2012, 08:55 -
Odd Audio Sync Problem
By Startropic1 in forum Video ConversionReplies: 0Last Post: 13th Aug 2010, 00:07 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 04:54 -
Video audio track cleaning problem
By efiste2 in forum AudioReplies: 1Last Post: 9th Feb 2008, 14:49 -
audio becomes a hiss
By ballboy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Jul 2007, 23:03
