    Sep 2010
    India
    I have a movie file of which description is
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : avc1
    Duration : 1h 34mn
    Bit rate : 2 500 Kbps
    Maximum bit rate : 23.9 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Minimum frame rate : 15.873 fps
    Maximum frame rate : 24.390 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.113
    Stream size : 1.64 GiB (87%)
    Writing library : x264 core 112
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=2500 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Encoded date : UTC 2015-10-19 18:55:29
    Tagged date : UTC 2015-10-19 03:42:15
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 34mn
    Bit rate mode : Variable
    Bit rate : 384 Kbps
    Maximum bit rate : 773 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : 83ms
    Stream size : 259 MiB (13%)
    Language : English
    Encoded date : UTC 2015-10-19 03:41:26
    I have tried multiple software to convert the aac component to ac3 while preserving the video component. Almost all failed when I chanced upon avidemux which gave the desired output as
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 1h 34mn
    Height : 720 pixels
    Color space : YUV
    Bit depth : 8 bits
    Encoded date : UTC 2015-11-18 16:23:04
    Tagged date : UTC 2015-11-18 16:27:13
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : ac-3
    Duration : 1h 34mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Bit depth : 16 bits
    Now that it was done, I wanted to soft-code subtitles into it. For this, according to forum posts, YAMB was an option that does it without altering video or audio components. I tried it but error comes up as
    [09:34:02] : YAMB 1.6.0 started !
    [09:34:02] : OS type detection...
    [09:34:02] : Home Edition (version 6.1, Build 7601 : Service Pack 1)
    [09:34:02] : Checking MP4Box location...MP4Box found.
    [09:34:02] : Checking MediaInfo.dll...0.7.1.2 found.
    [09:34:39] : Muxing started...
    [09:34:39] : Importing & Writing streams...
    IsoMedia import - skipping track ID 2 (unknown. Please check usage-----rest of the message is not present on the interface
    [09:38:25] : Muxing failed..
    Any suggestions anyone?
  2. Your log file says 1.6.0
    That version (and MP4) didn't support AC3 audio in MP4 back then. 2.1.0 beta 2 does . But even that is very old (2009), it will probably work but you should think about using a more modern mp4box build
    Sep 2010
    India
    Hi,
    Thanks for the suggestion. Downloaded the latest mp4box and then My mp4box GUI and tried. Error persists as video component and srt file gets muxed while audio is missed out.
