I have two .vob files and I want to change the main audio stream. I've used Avidemux to extract the audio and have remastered it in Audacity. Now I want to apply the new audio stream to the existing video without re-encoding the video and then be able to burn it to a dvd. What's the easiest way to do this using free tools?
Many thanks!
How do I do that? Are there any guides you could point me in the direction of? Sorry to be a nuisance.
I tried using Avidemux before but when I checked the video with Gspot the bitrate was different. Here's what I did - I changed the main stream to my remastered one and selected 'copy' for the video and 'ac3 aften' then saved as .TS - but when I opened it with Gspot it said the video bitrate had changed... -
so watch it and is whether ther really is a visible difference, or if its only some minor technical difference induced by the remuxing
1. Demux. One way is to open both VOBs together in DGIndex followed by File->Save Project and Demux Video.
2. Reauthor for DVD. Muxman. Open the M2V you got from DGIndex and the audio you made and author. I'll assume you made DVD-compliant audio. If not it'll be rejected by Muxman. If the combined bitrate is too high the muxing won't complete.
Neither of the programs mentioned is even capable of reencoding. -
How to Replace an Audio in a Video File
By x_man9989 in forum EditingReplies: 12Last Post: 4th Aug 2014, 08:15 -
How to replace the audio in a MOV file without converting the video?
By trasit in forum Video ConversionReplies: 7Last Post: 2nd Oct 2013, 03:43 -
Replace audio on .vob
By Flugplatz89 in forum Authoring (DVD)Replies: 18Last Post: 25th Sep 2011, 10:16 -
Replace about 50 frames of video in an .mpg file (keep audio the same)?
By gastrof in forum Newbie / General discussionsReplies: 6Last Post: 19th Jul 2011, 23:29 -
Possible to replace two scenes of AVCHD file without long re-encoding?
By mikeveli20 in forum EditingReplies: 20Last Post: 12th Mar 2011, 13:38
