  1. How convert video Using the program FFmpeg
    I want to explain with pictures
    Aug 2004
    PA USA
    In Linux open a Terminal window (Konsole in OpenSuse which I use) or in Windows open a Command prompt (cmd)
    sample
    ffmpeg -i somefile.avi somefile.mp4
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
    Great guide!
    Not. I'm moving you to our general video section.
    Aug 2004
    PA USA
    or
    ffmpeg -h
    for more help
  5. Originally Posted by kemo1000 View Post
    I assume you searching for explanation?
    As you didn't provided any details then i would advise you to check very good site https://trac.ffmpeg.org/ - everything is there - pictures are provided for examples also (some aspects video/audio processing) - encoding is plain command line - if you consider this to challenging i would advise you some ffmpeg gui frontend.
