https://www.youtube.com/watch?v=mLTJd34DDuM
in this video im using Sony movie studio 13 and am trying to add text. usually a new window will pop up where i can edit said text before inserting it but the window doesn't pop up and the "sample text" is used. anyone know how to fix this?
Results 1 to 9 of 9
Apparently there were some known bugs back in February that the latest updates fixed. As a licensed owner you are entitled to them for free. Also make sure your computer video drivers are up to snuff (though Movie Studio is pretty forgiving.) Not sure what else to try.
Have you tried to reset the software to default settings and preferences? Often worth at least a try with Movie Studio also. And as said, be sure to update to the latest build.
"If a program isn’t working right, just reinstalling it won’t necessarily fix it. You may need to reset the program to its default settings." -
So what happened is your text editing dialog box got commingled into one of the other frames.
Text with a line through it
By cornemuse in forum Off topicReplies: 1Last Post: 16th Oct 2014, 12:48 -
AviSynth : Text
By DayDreamer3d in forum EditingReplies: 4Last Post: 14th Oct 2013, 23:50 -
rtf text editor that allows black background & white text
By deadmeow in forum ComputerReplies: 4Last Post: 13th Dec 2012, 16:50 -
3d text in scene
By ZoNE97 in forum EditingReplies: 1Last Post: 14th Jun 2011, 16:35 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29
