Hello,
I have a mp4 movie file and separate srt subtitle file. How do I add srt into mp4 without hard-coding it? I don't want any re-encoding of the video or audio stream in mp4, but just merge subtitle to it. Is there any software for it? I found that handbrake tries to alter video-audio components when I try to add subtitle, or did I miss some settings in handbrake?
Thanks in advance
Use a multiplexer like Mymp4boxgui. Add the mp4. Add the srt. Click Save as and last click Mux.
Depends form player capabilities - hardcoded are most universal but this imply video recoding (as such long time and loss of quality).
Hi,
Just bought Bigasoft Total Video Converter 5 and tried to incorporate subtitle into mp4. I kept the video and audio as 'copy' mode and the preview video showed subtitle in it. But the product file did not incorporate it. Wrote a mail to Bigasoft and awaiting reply. Submitting query here to get quick resolution. Please...anyone...it is frustrating... -
Don't buy anything. Use My MP4Box GUI like Baldrick suggested.
They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Hi,
Yes I used mymp4boxgui but unsuccessful. I shall explain in detail
My initial mp4 is this
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Duration : 1h 34mn
Bit rate : 2 500 Kbps
Maximum bit rate : 23.9 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 15.873 fps
Maximum frame rate : 24.390 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.113
Stream size : 1.64 GiB (87%)
Writing library : x264 core 112
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=2500 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Encoded date : UTC 2015-10-19 18:55:29
Tagged date : UTC 2015-10-19 03:42:15
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 34mn
Bit rate mode : Variable
Bit rate : 384 Kbps
Maximum bit rate : 773 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 83ms
Stream size : 259 MiB (13%)
Language : English
Encoded date : UTC 2015-10-19 03:41:26
I wanted to recode aac to ac3 which I can do successfully using avidemux or Bigasoft TVC5. Both of them didnot alter video file like all other encoders did even when I chose video as 'copy'. I was told that medioinfo might give me wrong info as video altered, and so I used bitrate viewer to check the product files. The satisfied product file is this
Video
Format : AVC
Codec ID : avc1
Duration : 1h 34mn
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Encoded date : UTC 2015-11-18 16:23:04
Tagged date : UTC 2015-11-18 16:27:13
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : ac-3
Duration : 1h 34mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Bit depth : 16 bits
Now I want to incorporate srt subtitle file into this without any video or audio alteration. Bigasoft and mymp4boxgui replies as successul operation but srt never gets incorporated. Why is that?...or any other way or setting that I need to change?
Help is appreciated
If I try incorporating srt into original fine, everything goes fine and it gets incorporatedLast edited by socrates; 20th Nov 2015 at 12:16. Reason: additional info
Hi
May be you should post a short sample of your video + of the .srt file?
I just tested again: adding an .srt to a AVC H.264 MP4, that contains 6-channel .ac3 sound, and even a 2nd track: .mp3, 2-channel (simple test) — but using an old "Yamb 2.0/MP4Box" *, not "mympa4boxgui". It just worked (again)...
* Under (old...) Windows XP 32-bits. And under Win. 8 64-bits, with some problems in that case, to force "Yamb/MP4Box" to work (because of a wide screen PC...), but it worked also.
Attached: "MediaInfo" report.Last edited by bulgom; 20th Nov 2015 at 14:04.
Hi all
Thanks for the various suggestions and effort. I should say that that suggestion from bulgom solved the problem. Now I rencode aac to ac3 within mp4 without altering video using avidemux or Bigasoft TVC, and then use YAMB to mux srt subtitle into it. The resultant file is just the way I want it....whew! Thank you again- solved a month long of irritation....
what is the most easy way to add subtitle
By kenny1999 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Oct 2014, 23:00 -
how to add subtitle to mp4 so I can reencode it and hardcode/burn it?
By mrjayviper in forum SubtitleReplies: 9Last Post: 11th Mar 2014, 02:59 -
How to add Hindi Subtitle to any video
By J@Y in forum SubtitleReplies: 2Last Post: 30th Jan 2012, 13:08 -
add subtitle with mkv
By ali63 in forum SubtitleReplies: 0Last Post: 16th Dec 2011, 09:36 -
How to add Vietnamese subtitle ??
By caube in forum SubtitleReplies: 31Last Post: 17th Jan 2011, 17:16
