I've wondered about this for a while now but never got round to finding out why this happens.
Over time I've been backing-up my blu-rays and using handbrake for the encoding of the video. Now when I choose the FPS and the FPS mode, I choose constant framerate but when looking at the finished results with mediainfo, it shows that the FPS is variable and not constant. Why is this?
Results from mediainfo
If this is in the wrong section then admins/mods, feel free to move this to the correct section.Code:GeneralFormat : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 51.4 MiB Duration : 1mn 0s Overall bit rate mode : Variable Overall bit rate : 7 189 Kbps Encoded date : UTC 2036-02-06 06:28:16 Tagged date : UTC 2036-02-06 06:28:16 Writing application : HandBrake 0.10.2 2015060900 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1mn 0s Bit rate : 6 506 Kbps Width : 1 920 pixels Height : 800 pixels Display aspect ratio : 2.40:1 Frame rate mode : Variable Frame rate : 23.976 fps Minimum frame rate : 23.974 fps Maximum frame rate : 23.981 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.177 Stream size : 46.8 MiB (91%) Writing library : x264 core 142 r2479 dd79a61 Encoding settings : cabac=1 / ref=5 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.25 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=1 / chroma_qp_offset=-4 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=6506 / ratetol=1.0 / qcomp=0.80 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.10 / aq=1:0.50 Encoded date : UTC 2036-02-06 06:28:16 Tagged date : UTC 2036-02-06 06:28:16 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
You could try latest handbrake beta( https://handbrake.fr/nightly.php ) or vidcoder beta see how they work.
It's because of the timescale HandBrake uses. 23.976 is 24000/1001 fps rounded so for exact constant frame rate storing a muxer would have to use 24000 as a base for timings and then just stamps by 1001 for each frame. But HandBrake always uses 90000 for the timebase which means you cannot exactly represent 24000/1001 fps. You end up having to alternate between 3753 and for 3754 for the timestamp so you end up with a minimum and maximum of 90000/3753 ~= 23,981 and 90000/3754 ~= 23,974 fps, the average being ~23.976 fps.
For whatever reason, MediaInfo seems more likely to "correctly" interpret the frame rate type if the output is MKV rather than MP4, although I'm sure on occasion I've seen it label MKVs as variable frame rate which are supposed to be constant frame rate.
If it really bothers you, try opening the output video with a muxing program and remux while specifying the correct constant frame rate. It shouldn't have any noticeable effect aside from changing the way MediaInfo sees the video. It works when remuxing with MKVMergeGUI but for MP4's I'm not sure. You could try MyMP4BoxGUI to see if it does. -
Fantastic explanation! I always have wondered why that happens with Handbrake but never looked for an answer before now. Thanks!
Toshiba DX1215, Intel Core i5-2410 CPU 2.30GHz 2.30 GHz, 8.00 GB RAM, Windows 10 Home 64-Bit OS
Variable or Constant Framerate?
By JackDanielZ in forum Video ConversionReplies: 56Last Post: 4th Aug 2015, 08:14 -
Handbrake re-encode too pixelated at Constant Quality 20
By Knocks in forum Video ConversionReplies: 2Last Post: 25th Jan 2015, 18:03 -
Where is Constant Quality Rate in Handbrake?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2014, 22:39 -
Can the output file size in Handbrake's Constant Quality be determined?
By runlouierun in forum Video ConversionReplies: 5Last Post: 3rd Mar 2014, 14:18 -
Question about Handbrake's 'Constant Quality' setting
By Ronaldinho in forum Newbie / General discussionsReplies: 10Last Post: 8th Jun 2013, 03:55
