Hi,
I am outside UK and I am trying to download a video (http://www.bbc.co.uk/iplayer/episode/p02vmx6x/colour-the-spectrum-of-science-1-colours-of-earth) from bbc iplayer using methods given in this forum.
I can play the video in chrome using Hola vpn but when I try to download using the command -
youtube-dl --proxy "109.237.26.224:4444" -g -f best "http://bbc.co.uk/iplayer/episode/p02vmx6x/colour-the-spectrum-of-science-1-colours-of-earth" , I get the error as "ERROR: Unable to download webpage: <urlopen error [Errno 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond> " .
Please tell me how to download this video.
Thanks,
Results 1 to 10 of 10
Oh ok .. Can you please tell me how to get the rtmp code of video using Hola ?
I can play the video in chrome using Hola but I didn't know it can give the rtmp code also.. -
Can somebody please give me rtmp code for this video -
I am currently outside UK and I want to download this video. By going through the posts in this forum it seems rtmp code can be used in rtmpdump to download videos from bbc iplayer outside UK.
I have tried youtube-dl, wireshark etc but could not find rtmp code for this video... I don't know which is the best way to download videos from bbc iplayer outside UK .. -
hmm .. thanks for info about Hola.
http://www.bbc.co.uk/iplayer/episode/p02vmx6x/colour-the-spectrum-of-science-1-colours-of-earth, so that I can try in rtmpdump.
I tried some methods to get rtmp code but of no use..Any single tool to get the rtmp code from bbc iplayer videos outside UK? -
There's a reliable way of getting iPlayer videos as AdobeHDS fragments, then joining them. Once your browser is able to play those videos (using either that extention, or proper UK proxy), you can get download links with addblockplus plugin (I use it in Firefox, but it also exists for chrome). You can use the URL of any shown fragment (file name ends with ...Frag#) and download the manifest file (.f4m - just to find out the highest bitrate value, for new programs it's usually 5070000, 720p 50fps). Find out the approximate number of fragments by moving iPlayer's slider close to the end and use a browser extension for mass downloading. I use DownThemAll for Firefox; it only needs to modify a single url from 'host/...Frag#' to 'host/...Frag[1:last_number]'. Then you can join the fragments with KSV AdobeHDS script or with its standalone version (easier: works without php installation).
If smth. wrong with hola, you'll need to find a http proxy for getting the links and to find a working one after some testing (it must show you located in UK). It might appear too slow for continuous playback, but for getting links you only need to start it, then download via that proxy.
By using addblockplus plugin it is sometimes also possible to download xml file with rtmp links, but those I've looked into were only for SD, and sometimes didn't work (outdated info, etc.). You'd also need a template to use the parameters from xml (rtmp server name, authorization lines, file ID, etc.) in rtmpdump commands.Last edited by Alex_ander; 16th Dec 2015 at 08:58.
How to download a video from BBC iPlayer
By Joaquim_Link in forum Video Streaming DownloadingReplies: 34Last Post: 28th Mar 2016, 15:07 -
BBC iPlayer Audio delay
By efiste2 in forum Video Streaming DownloadingReplies: 2Last Post: 7th Nov 2015, 14:21 -
DRM protection on BBC iPlayer files
By Tafflad in forum Video Streaming DownloadingReplies: 5Last Post: 7th Jul 2015, 03:57 -
Download videos from Channel 4oD, Amazon, BBC iPlayer
By video2me in forum Video Streaming DownloadingReplies: 2Last Post: 22nd Oct 2014, 19:24 -
BBC IPlayer
By merryperson69 in forum Video ConversionReplies: 2Last Post: 18th Feb 2011, 13:13
