I want to know if i need to use IVTC. I'm converting NTSC DVD's to NTSC SVCD's but would like to make PAl SVCD's. Would IVTC help if i make PAL or NTSC SVCD's? Also should i use 3:2 pulldown to make Pal SVCD's. Finally how do i get rid of them black horizontal lines?
As far as I know, the best way to make a PAL from an NTSC DVD is to IVTC it (or use DVD2AVI's ForceFILM) so that you have a 23.976 fps FILM video. Then, take the sound through CoolEdit and speed it up by 25/23.976 and encode the FILM video at 25 fps (speeding it up by 4%). This is the way PAL DVDs are normally made from the original FILM.
There may be other, easier ways to do this, but I do the inverse of this to take PAL videos over to NTSC>
If by horizontal lines you mean the letterboxing - you don't get rid of it normally. If you mean the "interlacing" artifacts when playing on a computer, the IVTC will normally take care of it.
Another IVTC problem
By elmuz in forum RestorationReplies: 8Last Post: 29th Jul 2010, 03:49 -
By elmuz in forum RestorationReplies: 1Last Post: 26th Jul 2010, 10:16 -
IVTC - could someone help?
By Gew in forum Newbie / General discussionsReplies: 51Last Post: 8th Feb 2010, 21:26 -
ivtc help
By iamtehsux in forum Newbie / General discussionsReplies: 3Last Post: 20th Dec 2008, 19:58 -
IVTC Help!!!
By Martig in forum Video ConversionReplies: 1Last Post: 11th Jan 2008, 01:43
