Hi,
I made a mistake of joining 2 MP4 video files with HJSplit and now the single video file only plays part A even though the big file contains both parts. I believe the video header/index still thinks that it's only part A and needs to be updated.
I accidentally deleted the 2 original files so I cannot re-do. Any idea on how I can fix this?
Thanks in advance.
-V
Not sure if it's fixable (I've not come across something like that) but try MyMP4BoxGUI or even MKVMergeGUI (if you don't mind the final file being MKV). You might be able to open the MP4 with one of them and remux it as a playable file. If not, MyMP4BoxGUI can extract the raw video and audio streams and if it does so successfully you should then be able to use them to create a new MP4 or MKV.
Import and play a GIF as part of a clip - Flash Integro free video editor
By jdeb in forum EditingReplies: 4Last Post: 11th Nov 2015, 17:22 -
How to convert *.mkv to *.avi with copy video part and re-encode audio part
By pxstein in forum Video ConversionReplies: 13Last Post: 1st Aug 2014, 10:24 -
Play a video/game on 2 monitors + full screen on 1 monitor, surfing on 2nd
By WinSpecToR in forum ComputerReplies: 6Last Post: 23rd Feb 2014, 22:07 -
How to fast add 2nd track (mp3) to x264.hdtv.mp4?
By wacus in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2012, 07:05 -
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57
