Happy Saturday!and a simple question for which I've been unable to find a definitive answer. If I want to rip a Blu-ray, then use that rip as a source for denoising-shriveling in AviSynth, which would be the higher quality: VC-1 video at 13+ Mbps or AVC video at 14.0 Mbps High@L4.1? It seems to me that the original, unadulterated VC-1 video would be better, but perhaps the two-pass AVC is an improvement because it's able to redistribute bit rate more efficiently and that would translate to the encode? Thanks in advance for any clarification
If your original Blu-ray movie was encoded by the studio with VC-1, you should use that as the source material for any future processing/encoding.
An exact copy of what's on the Blu-ray disc is the best source, whether it be VC-1, h.264, or MPEG 2. Any re-encode with a lossy codec can only give you less quality.
Higher number of ReFrames = higher quality?
By ankutsa in forum Newbie / General discussionsReplies: 13Last Post: 8th Nov 2015, 18:08 -
x264 AVC High@L5.1 to High@L4.1 conversion
By Pr0metheus in forum Video ConversionReplies: 16Last Post: 11th Oct 2013, 15:37 -
What is the difference between x264 AVC High@L5.1 and High@L4.1?
By Bonie81 in forum Video ConversionReplies: 9Last Post: 26th Aug 2013, 20:40 -
What is the difference between AVC High 10 and AVC High?
By lawllmaster in forum Video ConversionReplies: 3Last Post: 29th Mar 2013, 04:29 -
Does it make sense to use higher bitrate than source AVCHD?
By cheerful in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Dec 2010, 04:13
