Ive been using MVToolNixGUI for some time without any problems. Im removing the non english audio by unticking it and pressing the 'Start Muxing' button, which for the first few files worked fine. However it now flashes errors and crashes. It doesn't say what the errors are and can't seem to find a way to find out.
Any ideas or suggestions for another program that will do the same job.
Thanks in advance
James
Seem to have solved the problem. Even though I had over 100GB of free space, I moved some files onto a different drive freeing up loads of space and the problem seems to have gone away. Maybe the program requires a minimum amount of free space to work
Errors in HandBrakeCLI
By astronauta in forum DVD RippingReplies: 4Last Post: 16th Aug 2015, 18:59 -
Encoding Errors
By KevinL in forum RestorationReplies: 11Last Post: 25th Jan 2014, 08:14 -
Detecting errors
By leftspeaker2000 in forum Video ConversionReplies: 2Last Post: 1st Nov 2012, 10:59 -
A Few Different Errors with Ripbot
By Rod419 in forum Blu-ray RippingReplies: 3Last Post: 29th May 2012, 00:13 -
MEGui errors,
By krohm in forum Video ConversionReplies: 8Last Post: 16th Nov 2010, 09:31
