Hi everyone,
I'm new. Could not figure out how to post a new thread on my own. Thanks to usually_qiuet for the sticky. And I'm am not a grave digger type, suggested by a poster.
Anyways, I'm using a camera at school to capture some footage; panasonic ag hmc40, cmos 3. I'm not sure what I touched while I'm out in the field, but a message, 'meta' , comes up on the screen. The camera eventually shuts off as I try to do something with it ( just anything to get it working). I don't know if anyone ever used this camera and had this situation occurred. Please help if you can, as I 'm stuff on my class project.
Thank you
Looks to be one of the recording functions. From the operating manual:
I found a manual online that might help:Meta-data recording:
The date, camera operator, location, title and other information can be
added to the video data.
http://www.manualslib.com/download/117253/Panasonic-Avccam-Ag-Hmc40.html -
I have that same model but havenīt seen that message (or used that feature), you can reset the camcorder to factory specs,while in camera mode enter MENU/OTHER FUNCTIONS/MENU INIT, choose YES
@redwuz..Iīm afraid thatīs not the cammcorderīs manual, just a brochure of its features. I found my manual, but only the printed version (itīs like a short version, with only basic features explained) I canīt find the (more complet) PDF version, maybe there it explaims better the meta data recording or meta mark functions. -
The one I was trying to show was: http://www.manualslib.com/manual/360791/Panasonic-Ag-Hmc40.html
It's 122 pages. But I didn't read it and it may not be exactly the right manual.
Thank you guys, I'll check it out on Monday when I go back to school.
munch
AVCHD to DVD headache
By rdoty in forum Authoring (DVD)Replies: 4Last Post: 15th Oct 2015, 18:20 -
Is Panasonic AG-HMC40 HD a good camera?
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 49Last Post: 28th Jul 2013, 13:22 -
Analog/digital TV issue (*headache*)
By jf998247 in forum Newbie / General discussionsReplies: 6Last Post: 18th Jan 2013, 02:42 -
What do you take for a headache?
By johns0 in forum PollsReplies: 24Last Post: 14th Mar 2012, 16:19 -
3 TB HD headache
By Farscape1 in forum ComputerReplies: 12Last Post: 16th Jun 2011, 01:09
