I have some video files where I want to keep a certain part of video with its audio. But replace opening text with blank video. But keep the audio & video in place. Everything matches resolution, audio etc. I just want to replace beginning & ending video with blank video keeping the audio with reconverting
In earlier posts you say you have Adobe Premiere. That should do it easily.
But that does not accept mp4. I want Direct Stream Copy editing. No conversion which is needed for Adobe Premiere & 6.0 does not do Direct Stream Copy & the new versions really suck ass
I doubt you will find any simple to solution to avoid reconverting. Maybe if you find a super editor software that supports smart rendering(no reconversion for the video parts you keep) for your exact mp4 source.
You may be able to use something like AviDemux.
Convert your original audio to PCM wav
Make your video changes in AviDemux keeping audio and video married.
Export video in copy mode. (This is of course dependent on your video files actually matching.)
Export your edited Audio as PCM wav
Bring your original audio and edited audio into your ancient 2001 edition of Premiere and see if they still match -- if not make adjustments so they do.
Output the final audio from Premiere as PCM wav
Mux the new video and final audio with ffmpeg, converting only the audio to (most likely) AAC.
(BTW, current versions of Premiere have matured to be stable, professional reliable tools. I'm betting it's the licensing scheme you don't like.) -
Video To Video editing question
By RockerAce in forum EditingReplies: 24Last Post: 13th May 2015, 13:20 -
Editing an AVI file question please
By Estam in forum EditingReplies: 10Last Post: 25th Oct 2013, 11:08 -
Building PCs for video editing class and have a question.
By ingeborgdot in forum EditingReplies: 12Last Post: 5th Jun 2013, 14:09 -
Editing Question about Virtualdub
By gatewayedit in forum EditingReplies: 5Last Post: 14th Jul 2011, 16:26 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29
