I have several little 250-400 mb mp4 file and would like to split them a specific points of the file of my choosing then save the resultant file. What software does this? JOhn![]()
mp4splitter, avidemux, xmedia recode, etc.
But you can only cut at keyframes without reconverting. -
What I'd like to know is if there's any H.264/AVC editor that works very much like Womble MPEG Video Wizard does for MPEG-1/2. Something that renders cleanly, but will re-encode a few frames near the cuts and joins. Don't mind paying for it either if no free one is available.
EDIT: These are files that I encoded myself, from MY personal source, not "acquired" from some "online distribution". Never needed such software previously, but now, some years later, I wish to make some changes on some files since, silly me, I would delete some source back then after some encodes. (Otherwise I'd work from the Source instead.)Last edited by PuzZLeR; 5th Nov 2015 at 11:50.
I hate VHS. I always did. -
"smart rendering" software. eg. videoredo, solveigmm video splitter, tmpgenc smart renderer
Cool thanks!
Maybe I'm pushing it, but are there any tools, or any from your list, that also do fades (in/out) at cuts and joins? For some content, this makes it look less abrasive to me than a straight cut/join.
Sure I could put together a workflow with some scripts for this, but direct would be better.I hate VHS. I always did. -
TMPGEnc Smart Renderer and PowerDirector are supposed to support transitions (obviously those sections would be re-encoded). I haven't used them.
I don't know how "good" they are in terms of compatibility etc.. Since there are wide varieties of AVC, settings etc...
Sony Vegas does for AVCHD and MPEG2, but it can be difficult to "convince" it to work for some streams -
I have no problem with these sections being re-encoded, I expect that, but you said it right about my concern in that there are different profiles, etc, for AVC, and I'm not sure if the resulting video will be problematic in the end if the re-encoded parts have different b-frames, refs, profile, etc.
I always loved TMPGEnc MPEG Editor, but they also had, or maybe still have, a version of their app that did transisitions. This one was terrible and always crashed, even support would admit it. This was a few years ago, but I'm still not feeling confident about it with AVC now. But hey, it may be worth a re-try.
I don't trust Vegas, as was discussed in another thread. Power Director seems worth a try though.
Then again, at worst, I can always use something from your original list, with a few scripts in the workflow. More work, yes, but at least it will work properly since I would know how to re-encode those small fragments given that it was my work to begin with.
Thanks.
I need a mp4 Cutter/Splitter
By minegroasprilla in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jan 2015, 18:04 -
using Gabset MP4 splitter
By A700 in forum Software PlayingReplies: 10Last Post: 7th Oct 2014, 12:29 -
MP4 splitter/cutter
By insidesafstand in forum EditingReplies: 2Last Post: 5th Jul 2014, 22:32 -
Windows MP4 splitter with overlap?
By yetanotherlogin in forum EditingReplies: 0Last Post: 19th Jun 2014, 06:27 -
Fast MP4 splitter, does it exist?
By Bencuri in forum EditingReplies: 1Last Post: 25th Sep 2012, 17:11
