Hi,
I recently uninstalled the k-lite codec pack after having problems with pc lockups when viewing videos.
I installed the program InstalledCodec from nirsoft that loads up all the codecs on the computer. It highlights ones that are faulty and not working properly.
I'm still getting lock-ups after removing the k-lite codec pack, and today I loaded up InstalledCodec and it says there is an issue with these codecs;
MainConcept MP4 Demultiplexer
MainConcept MP4 Push Demultiplexer
MainConcept MPEG Demultiplexer
MainConcept Stream Parser
So I'm wondering where I could re-download these codecs from? When I did a search online it took me to the mainconcept dot com website that was selling them as a package. I don't want to pay for codecs.
Oh, also I did uninstall a DivX player yesterday too, so maybe they are left over from that?
The Stream Parser was installed on the 7th of October 2012, while the others were installed more recently on 10th of October 2015.
Anyone any ideas what I should do? The InstalledCodec program as the option to disable the codec. Shall I do that? Do I even need those Codecs? By the way they are all DirectShow Filter types.
Uninstall all the codec packs and instal LAV Filters.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
I only had k-lite codec pack installed.
From what I can tell after poking around some more, is that they are from the DivX player I had installed. I uninstalled that yesterday. I guess it didnt remove all of its codecs.
Is it possible to remove individual codecs? If so, how is this done? At the moment I've disabled those codecs highlighted.
Display problem after pc upgrade (codecs missing?)
By boko in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2014, 02:59 -
LG Recorder RH278H hard drive faulty
By hendrikbez in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Jan 2014, 04:45 -
Is this a faulty capture card?
By slow in forum Capturing and VCRReplies: 4Last Post: 20th Mar 2013, 19:23 -
Missing codecs after update of K Lite
By Zoro83 in forum Newbie / General discussionsReplies: 7Last Post: 9th Apr 2012, 10:46 -
VirtualDub Compression Codecs All missing?
By blazr in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2012, 05:14
