can i burn a m2v movie?if so what program can i use to convert it?
help
hjCode://
Well i try every day..but i'll **** a virgin soon
m2v??? isn't that an svcd stream??? or from CCE??? have you tried to multiplex that with the sound in TMPG???
How did you encode this .m2v? Usually this is the extention for MPEG-2 video (no audio).
Plus it would help to know if you are on a MAC or pc.....not that I favor one over the other.
m2v is an svcd stream. you can just rename the extension to mpg. personally, i like to use tscv to create a bin/cue file to burn, you can just add the mpg files and click "create bin/cue"
hope this helps
Shaggy -
yea i also download a music video that has the .m2v extension, it says its a xsvcd. Oh yea and there is sound, i could only open it with my power dvd. if your trying to convert the .m2v into a regular vcd (mpeg1), I don't think u can just rename it to .mpg, u might have to encoded it to mpeg1
When I create a mpeg2 file with my aiw card, the extension it is given is .mp2. After renaming it .mpg its accepted as a mepg2 file by tmpg and m/s media player (make sure media player has the mpeg2 codac too run it.
m2v extensions are basically same as dvd video.
Use dvd2avi to create a project of your m2v file and then encode it to mpg(vcd) in tmpg.
simple as that.
640x480 14,9fps video from mobile to 25/30 fps posible?
By mammo1789 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 17th Mar 2012, 07:06 -
Pal users when capturing always use scart when posible
By mammo1789 in forum Capturing and VCRReplies: 1Last Post: 21st Oct 2011, 12:28 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
muxing m2v with m2v?
By just in forum Newbie / General discussionsReplies: 4Last Post: 30th Dec 2008, 01:05 -
How Do I convert DVD Episodes in AVI in 350MB in highest quality posible
By Rockstar452 in forum DVD RippingReplies: 4Last Post: 29th Oct 2007, 04:39
