Results 1 to 24 of 24
    Jan 2001
    Format                                   : Matroska
    Format version                           : Version 4 / Version 2
    File size                                : 2.54 GiB
    Duration                                 : 1h 39mn
    Overall bit rate                         : 3 636 Kbps
    Movie name                               : Movie name
    Encoded date                             : UTC 2015-10-28 18:04:25
    Writing application                      : mkvmerge v8.3.0 ('Over the Horizon') 64bit
    Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
    Ripped by                                : The Encoder
    Video Source                             : Untouched BD50
    DURATION                                 : 01:39:11.112000000
    NUMBER_OF_FRAMES                         : 2314
    NUMBER_OF_BYTES                          : 6624704
    _STATISTICS_WRITING_APP                  : mkvmerge v8.3.0 ('Over the Horizon') 64bit
    _STATISTICS_WRITING_DATE_UTC             : 2015-10-28 18:04:25
    _STATISTICS_TAGS                         : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    How can you add these extras in the General information part?
    Ripped by
    Video source
    I have been looking but unsuccessful.
    Sep 2012
    Australia
    MKVExtract Tags
    Jan 2001
    So it can't be done with just MKVToolNix GUI?
    Sep 2012
    Australia
    As far as I can tell there's no official header element for it, and inventing one would only lead to woe.
    There's no official tag for it either, but that's the only place it could be so you should extract the tags and look.
    And no, MKVToolNix GUI doesn't handle tags and whatever MediaInfo is reading isn't in the Matroska Specs.
    Jan 2001
    Can those tags be edited?
    Sep 2012
    Australia
    Yes, using a text editor (or xml editor) and mkvpropedit.
    Jan 2001
    It's a little more complicated but I am starting to figure it out.
    Jan 2001
    mkvpropedit doesn't allow me to edit the xml file and save
    Global tags are more difficult to edit I believe
    Sep 2012
    Australia
    Extract the tags with MKVExtract, edit them with a text/xml editor and add them to a file with MKVPropEdit...
    Global Tags are just track tags with no target. If you're talking about "levels" you can just ignore that, the matroska specs failed to spell out how any of it worked so the tagging system is a dud.
  10. Originally Posted by Ally68 View Post
    Format                                   : Matroska
    Duration                                 : 1h 39mn
    Ripped by
    Video source
    This is easy:
    1. create with editor a file.xml with this text:
    <Tags>
    	<Tag>
    		<Simple>
    			<Name>Ripped by</Name>
    			<String>flashandpan007</String>
    		</Simple>
    		<Simple>
    			<Name>Video Source</Name>
    			<String>Untuched BD50</String>
    		</Simple>
    	</Tag>
    </Tags>
    2. Open MKVtoolnix drag your file and in Output/global tags open this xml file
    3. merge it and done
    Jan 2001
    Thank you, I figured it out. Now if only I could remove those ridiculous tags from mkvtoolnix that started in v7.0.0
  12. In preferences of the new gui you can add --disable-track-statistics-tags to default additional cmd line options.
  13. does it work for you? second tab in the middle of options ...
  14. Yeah, mediainfo shows no statistics tags when you apply it. You can add it manually or click on the button and select from the list of available options.
    Jan 2001
    Where exactly do you add [--disable-track-statistics-tags]
  16. In new gui open preferences window, "merging" tab and "default additional command line options" under general options.
    Sep 2012
    Australia
    You might want to hold on that. I'm in the middle of getting MediaInfo's crappy handling of the statistics tags fixed right now.
  18. Member
    Sep 2012
    Australia
    OK....
    Here's a version of the MediaInfo dll that will process the tags properly (ie you can't see them now, but now you CAN see the bitrate for DTS-MA).
    Put it in the MediaInfo program folder as is and it should work.
    It's a 32 bit debug version because my compiler crashes on the release version but it should be ok until the next version of MediaInfo is released.
    -edit- are we not allowed to upload dlls?
  19. Originally Posted by Ally68 View Post
    You can use my chapterEditor, there is a Matroska TAGS editor inside!!
    Jan 2001
    I tried this and made sure it was selected. It still wrote the tags
  21. It has to work but the setting will probably only be used for new jobs. If in doubt restart Mkvtoolnix GUI and try again.
  22. Member
    Sep 2012
    Australia
    Keep the tags, download the dll and they'll never bother you again.
  23. Member
    Jan 2001
    You were right, I forgot to uncheck the tag so it still had it selected yes to mux.
    Thank you everyone for the help!
