  1. Hi, in encoding with Ripbot 19.2 this error is shown :
    (avs2yuv.exe has stopped working)
    I installed avisynth and ffdshow, but Ripbot still gives error.
  2. DECEASED
    Jun 2009
    Heaven
    PERHAPS the actual problem is in RipBot itself
    If I were you, I would send a P.M. to Atak Snajpera, the author of RipBot264.
    And surely you will have to provide much more info...
  3. source file's MI:
    General
    Unique ID                   : 244725278789986233051346560410547112541 (0xB81C5FCF4EC7489C87E41BA60E6BCA5D)
    Format                      : Matroska
    Format version              : Version 2
    File size                   : 3.28 GiB
    Duration                    : 48mn 11s
    Overall bit rate            : 9 740 Kbps
    Encoded date                : UTC 2010-03-13 03:23:44
    Writing application         : mkvmerge v3.1.0 ('Happy up here') built on Jan 19 2010 12:09:24
    Writing library             : libebml v0.7.9 + libmatroska v0.8.1
    Video
    Format                      : AVC
    Format/Info                 : Advanced Video Codec
    Format profile              : High@L4.1
    Format settings, CABAC      : Yes
    Format settings, ReFrames   : 4 frames
    Codec ID                    : V_MPEG4/ISO/AVC
    Duration                    : 48mn 11s
    Bit rate                    : 8 231 Kbps
    Width                       : 1 920 pixels
    Height                      : 1 080 pixels
    Display aspect ratio        : 16:9
    Frame rate mode             : Constant
    Frame rate                  : 23.976 fps
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Progressive
    Bits/(Pixel*Frame)          : 0.166
    Stream size                 : 2.71 GiB (83%)
    Writing library             : x264 core 88 r1471 1144615
    Encoding settings           : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8231 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language                    : English
    Default                     : No
    Forced                      : No
    Audio
    Format                      : DTS
    Format/Info                 : Digital Theater Systems
    Mode                        : 16
    Format settings, Endianness : Big
    Codec ID                    : A_DTS
    Duration                    : 48mn 11s
    Bit rate mode               : Constant
    Bit rate                    : 1 509 Kbps
    Channel(s)                  : 6 channels
    Channel positions           : Front: L C R, Side: L R, LFE
    Sampling rate               : 48.0 KHz
    Bit depth                   : 24 bits
    Compression mode            : Lossy
    Stream size                 : 520 MiB (15%)
    Language                    : English
    Default                     : Yes
    Forced                      : No
    Text #1
    Format                      : UTF-8
    Codec ID                    : S_TEXT/UTF8
    Codec ID/Info               : UTF-8 Plain Text
    Language                    : English
    Default                     : No
    Forced                      : No
    Text #2
    Format                      : UTF-8
    Language                    : French
    Default                     : No
    Forced                      : No
    Menu
    00:00:00.000                : en:01
    00:04:05.245                : en:02
    00:16:18.811                : en:03
    00:25:56.555                : en:04
    00:39:03.174                : en:05
    00:47:26.677                : en:06
