Results 31 to 37 of 37
I've attached the text of the media info so that some miscommunication doesn't occur.
In the General it shows Matroska specified.
In Video what I see is an MPEG-4. -
My screen shot of the placement of the pplugin x64 for Virtual dub attached
Are you running 64 bit VirtualDub? The 64 bit MKV plugin will not work with 32 bit VirtualDub. And vice versa. I recommend you use 32 bit VirtualDub. Many 3rd VirtualDub filters are not available in 64 bit versions.
AVI Demux was mentioned earlier with a graphic aid for making the file edit.
I currently have AVI Demux loaded with another job wherein I want load an AVI video
and put in an Ogg VCorbis sound track I built which is the same length. It's a process I do
with other formats.
But I'm not sure what AVI Demux is doing. I have gone to this because one of the Virtual Dubs-- Virtual Dub Mod which shows the stream lists did the remux action but had no sound.
If I need a fresh thread I can make one. AVI Demux can use an Ogg file. But how is it entered and replaced in the AVI? I'm looking at it but what it looks like is AVI Demux can
make an output file _as_ Ogg just in it's program. Enlighten me where my error is.
This is a whole different operation of cutting and editing.
virtual dub appending files
By erzane in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2015, 06:29 -
Virtual Dub Can't Recognize mkv files... tried nearly everything.. help?
By CherryBelle in forum Newbie / General discussionsReplies: 12Last Post: 13th Apr 2014, 22:20 -
Advice on VHS to DVD workflow and Virtual Dub Settings?
By zoink187 in forum Newbie / General discussionsReplies: 80Last Post: 20th Mar 2014, 13:07 -
Is there a program similar to TMPGEnc for .mp4 and .mkv files?
By Shinjikun in forum Newbie / General discussionsReplies: 5Last Post: 9th Sep 2012, 15:15 -
A simple video editor - that works with MKV files (important!)
By jin37uk in forum EditingReplies: 2Last Post: 20th Dec 2010, 22:10
