  1. anybody can help about how can i rotate a MP4 video file 90 degree right side ?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Name:  rotate search.jpg
    Try it......
  3. Member DB83's Avatar
    Jul 2007
    Not possible with re-encoding
    canada
    Turn your tv/monitor on its side,seriously it has to be re-encoded,no way around that.
  5. i can try encoding file with same bitrate...But need Tools for this...give me some name please....
  6. Member DB83's Avatar
    Jul 2007
    You can rotate most video with avidemux.
    Load your video. From the 'video' menu select 'Filters'/'Transform'. You will then see the rotate option.
    You can then try 'Copy' for video and audio. Select your Output Format. That should leave bitrate alone but it will still re-encode due to the rotation.
  7. Member Cornucopia's Avatar
    I've already explained in a previous post how to do this losslessly without re-encoding in QuickTime. It is quite doable. The problem is not in the editing/saving, it is in the player supporting the rotation flags.
  8. Yes. Avidemux is work fine for this...
