I'm trying to load up a .TS file into AVIDemux. It loads fine, but when I try to play it, I get the error:
"Info: Trouble initializing audio device"
This is the first file with surround sound audio that I've tried to do with 2.6.10, so I'm not sure if that is part of the problem.
MediaInfo below:
I've previously had audio issues with some other .TS files, but converting them to MPEG4 with WinFF always fixed it. With this file, WinFF immediately fails.Code:General ID : 0 (0x0) Complete name : [redacted]\HDPVR2_[redacted].ts Format : MPEG-TS File size : 9.61 GiB Duration : 1h 56mn Overall bit rate mode : Variable Overall bit rate : 11.8 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : 27 Duration : 1h 56mn Bit rate : 10.8 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.174 Stream size : 8.81 GiB (92%) Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 1h 56mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : -377ms Stream size : 320 MiB (3%)
Any help appreciated in advance.
	Have you tried older versions of avidemux? Newer versions might not work perfect.
 https://www.videohelp.com/software/AviDemux/old-versions#download
  Trouble with audio speed and syncingBy Solowing in forum AudioReplies: 15Last Post: 14th Aug 2014, 00:35
  Subtitle outline render trouble with AvidemuxBy Coco_coco in forum SubtitleReplies: 11Last Post: 8th Mar 2014, 11:04
  Trouble with component usb cap device.By roy.walters in forum Capturing and VCRReplies: 2Last Post: 15th Dec 2011, 21:12
  Trouble Editing/Trouble Base Media?By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 20:53
  multiple trouble with audio while working with VDub 1.9.10By sorophx in forum AudioReplies: 4Last Post: 28th Dec 2010, 23:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
