Can anyone plz help me with this
i tried yamb but no use also tried mp4 joiner and its stops responding
Hi
Kind of fussy! So keep a life jacket at hand, or a beer, may be — but just tested again: it worked, with "Yamb/MP4box"...
Note · for me anyway, it did NOT work (at all!) using any .mp4 file with any ".idx + .sub" files: I had to use an .mp4 clip previously converted from a .VOB (MPEG-2 DVD) file...
... as the corresponding ".ifo" file was required!
So:
1. .VOB converted to .mp4, using "AviDemux" (in my case). To TEST, pick a lightweight .VOB file...
2. The .ifo" file that comes with the original .VOB is needed.
—— Keep all three (.VOB + .IFO + .mp4) files in one same folder. —–
3. Also required: "VobSub" plug-in, in "VirtualDub" "plugins32" subfolder.
Start "VirtualDub", no need to open any video; menu Video > Filters > Add, & double click "VobSub 2.23";
on "Filter: VobSub" window, click Open button. Bottom of "Open" window (File types field), select "Ifo and Vobs for creating idx/sub (*.ifo)". Browse to the folder containing the 3 files and click the ".ifo";
"VobSub" asks where to save the result: browse/indicate the SAME folder again.
Next window, titled "Select PGC": just click OK for now (simple test). And let it convert, until it displays "Ready". Then, click OK button, and quit "VobSub" + "VirtualDub" (quit everything).
4. Now, the folder contains two more files: the ".idx" + the ".sub".
Start "Yamb/MP4box". Click 1st option (top: "MP4 creation..."). Drop the ".mp4" video, and the ".idx" file only, to "Yamb" window. Bottom ("Output" field), don't browse to another location, but modify the video file name you want:
i. e., if you have C:\folder\test.mp4 modify to C:\folder\test_result.mp4 (or whatever DIFFERENT name than your original .mp4). And click "Next" button.
If it works, buy yourself a beer — plus one for me (Chinese "Tsing Tao", please). If it (still) does NOT work, do the same.
.Last edited by bulgom; 31st Oct 2015 at 20:34.
I would be inclined to convert the IDX/SUB to SRT. Plenty of good tools to do that now with minimum editing.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
That's what I do mostly. Way simpler, lighter. And works quite well (except with very stubborn players).
Now, ".idx + .sub" subtitles have certain advantages, over ".srt", one being: they can be "tweaked", in order to use them as TITLES * (instead of SUBtitles). There is also the ".ass" format, graphically more advanced than ".srt"...
* I'm trying to concentrate on that, or rather: by using ".png" images, overlaid on ".mkv AVC H.264" video, here: https://forum.videohelp.com/threads/375001-%5Bhow-to%5D-Overlay-image-title%28s%29-on-A...ding?p=2417007
How to convert idx/sub files to sup?
By mrjayviper in forum SubtitleReplies: 2Last Post: 5th May 2014, 00:14 -
Avidemux. What am I do with idx files?
By pssheba in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2013, 08:04 -
.srt->sub/idx won't show in a multiplexed .mp4 - Why & how can I change it?
By Fańch in forum SubtitleReplies: 7Last Post: 11th Mar 2013, 02:15 -
Where does Avidemux store idx index files?
By Gibson's Squares in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2012, 20:30 -
How to add idx/sub hard subtitles to mkv
By 2ndlife in forum SubtitleReplies: 5Last Post: 29th Dec 2011, 21:22
