It's importing as though it were a video-only file, with just the filmstrip icon next to it in the project panel.
A Google search turned up nothing but threads from years ago, before Premiere supported the format at all. The video works fine.
It's the result of a capture from a Blackmagic Intensity Shuttle.
MediaInfo:
Any help?Code:Format/Info : Audio Video Interleave Format profile : OpenDML File size : 49.9 GiB Duration : 1h 9mn Overall bit rate : 103 Mbps Video ID : 0 Format : JPEG Codec ID : MJPG Duration : 1h 9mn Bit rate : 100 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 1.935 Stream size : 48.8 GiB (98%) Audio ID : 1 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : 00001000-0000-0100-8000-00AA00389B71 Codec ID/Hint : Microsoft Duration : 1h 9mn Bit rate mode : Constant Bit rate : 2 304 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 24 bits Stream size : 1.12 GiB (2%) Interleave, duration : 1000 ms (25.00 video frames)
Results 1 to 13 of 13
90% of what I come across is 16bit.
90% of what causes problems for me is something that is not 16bit. -
I don't have anything "24bit" here to play with, but I would think that you can just create a new 16bit audio from the present one by dragging the video file into something like GoldWave or Audacity, changing it to 16bit, then outputting a new WAV audio file.
You'll have just audio though.....no video. You'll have to find a way to demux and remux(exchange) the new audio for the old audio. You'll need to create another 49GB file though. -
Surely I could just import the avi file into Premiere for the video, and the new WAV file for the audio? Then just link them in the timeline, so it treats them as one file.
Edit: Trying to import the AVI into Audacity has completely locked up my computer two out of the three times I've tried. Had to hold down the power button for about ten seconds just to get it to even reboot.Last edited by koberulz; 30th Oct 2015 at 15:29.
I don't use premier so I have no idea.
I rarely use Audacity. I use GoldWave...but I usually get shouted down AUDACITY IS BETTER by other VHelp members so that is why I include it in my suggestions.
I know there is a way of using VirtualDub to save audio from a file, but I haven't done that for a while either. I stay the HELL away from any audio that is not 16bit......especially my recordings/captures. -
You can use Audacity to work on the audio portion of video files, but to do so requires linking up to ffmpeg as a plugin, and that used to require a specific build of Audacity for it to work (and possibly a specific build of ffmpeg).
Also, since this process is not optimized for video, it will take a LONG time to load in the file - to the point where you might think it's frozen.
Better, IMO, to just demux and convert directly with ffmpeg, then load them in separately like you were thinking.
Scott -
Using VirtualDub to save as a WAV file results in a 24-bit file that works fine in Premiere. The AVI just shows up as a video-only clip, though.
Okay, the 24-bit files no longer work in Premiere. I get an error saying it couldn't be imported due to a header error.
Opening in Audacity and then just exporting as a WAV gets me a file I can import, though. And the two processes combined are still faster than opening the AVI in Audacity was, so there's that.
Can Premiere Pro CS6 export at 18fps?
By Ikejohn in forum EditingReplies: 19Last Post: 25th Sep 2015, 07:55 -
Premiere Pro CS6 final encoding questions
By Rudyard in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2014, 23:54 -
Final Cut Pro X vs Adobe Premiere Pro CS6 for capturing/digitising DV
By danvideodiary in forum Capturing and VCRReplies: 11Last Post: 7th May 2014, 19:28 -
Flack audio output for videos in Premiere pro CS6
By Stears555 in forum Video ConversionReplies: 2Last Post: 12th Mar 2013, 21:09 -
Laptop for Adobe Premiere Pro CS6
By Amira_S in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2012, 11:01
